+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Newbie level 5
    Points: 1,344, Level: 8
    Achievements:
    7 years registered
    Join Date
    Oct 2010
    Posts
    10
    Points
    1,344
    Level
    8
    Single phase to three phase converter for driving three phase induction motor.
    I am doing my project on the topic (Single phase to three phase converter for driving three phase induction motor.)
    Can Any one upload data or link related to
  2. #2
    Advanced Member level 2
    Points: 5,775, Level: 18
    Achievements:
    7 years registered
    Prototyp_V1.0's Avatar
    Join Date
    Apr 2007
    Norway
    Posts
    644
    Points
    5,775
    Level
    18
    Re: Single phase to three phase converter for driving three phase induction motor.
    You can connect a capacitor like this (see picture)
    2 members found this post helpful.
    •   Alt28th February 2011, 19:18
      advertising
  3. #3
    Member level 3
    Points: 1,538, Level: 8
    Join Date
    Oct 2010
    Singapore
    Posts
    59
    Points
    1,538
    Level
    8
    Quote Originally Posted by Syed Ali View Post
    One way is you can convert single phase AC to DC (rectifier) and then convert again to three phase AC by using inverter. I assume the energy from single phase side enough to drive three phase motor.
    •   Alt1st March 2011, 02:22
      advertising
  4. #4
    Newbie level 5
    Achievements:
    7 years registered
    Join Date
    Oct 2010
    Posts
    10
    Points
    1,344
    Level
    8
    Quote Originally Posted by eiphan View Post
    yes eiphan i have this idea, but i don't have sufficient data related to this.....can you further help me.. i have the block diagram related to my project idea here it is [IMG][/IMG]
    ---------- Post added at 17:09 ---------- Previous post was at 17:07 ----------
    ---------- Post added at 17:16 ---------- Previous post was at 17:09 ----------
    Quote Originally Posted by Prototyp_V1.0 View Post
    Thanx Prototyp_V1.0
    But my idea is different which i want to implement...
    Here is the block diagram of my idea.
    •   Alt1st March 2011, 17:16
      advertising
  5. #5
    Member level 3
    Join Date
    Oct 2010
    Singapore
    Posts
    59
    Points
    1,538
    Level
    8
    From what I see from the diagram, you may want to use PFC rectifier circuit with thyristor control or PWM IGBT control. I recommend IGBT depending on the rating of your system. First, I suggest you to make SM rectifier to regulate the DC link voltage while maintaining power factor to near unity. Once it is done, you can proceed to implement three phase inverter with whatever control scheme that you like. again I recommend IGBT for switching and you can even implement regeneration. you might have appropriate controller for the system. I want to refer to power electronics book written by Ned Mohan. The book can explain this idea. Please let me know if you need any more help.
    1 members found this post helpful.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Norway
    Posts
    644
    Points
    5,775
    Level
    18
    The device your project is about is called a frequency converter.
  7. #7
    Full Member level 5
    Points: 1,934, Level: 10
    Join Date
    Feb 2009
    Posts
    245
    Points
    1,934
    Level
    10
    I don't think it can be called as frequency converter. Please do correct me if I am wrong as I am not power guy. He will be still using the same 50Hz or 60Hz. He wants to convert the single phase 230V to 440V diveded into 3 phases using IGBT. This is normally done in UPS, inverters etc for delivering 3 phase from a single phase if I am not wrong.
    Thankyou
  8. #8
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Norway
    Posts
    644
    Points
    5,775
    Level
    18
    Quote Originally Posted by prmurthy View Post
    Thankyou
    I beleive that even if the user want it to have a fixed frequency, it's still gets under definition of frequency converter.
    Definition from wikipedia:
    Quote Originally Posted by wikipedia
    frequency changers are also used to control the speed and the torque of AC motors
    After all, the device will let the user easilly change speed (and thus frequency) of the AC motor. The user just decide to not take advantage of the other nice features of the device.
  9. #9
    Full Member level 5
    Join Date
    Feb 2009
    Posts
    245
    Points
    1,934
    Level
    10
    THIS IS REPOST BECAUSE I DELETED BY MISTAKE NO ACTION TO BE TAKEN ON THIS PLEASE.
    He is looking something like this one
    Please refer to micochip site. Full development kit is available.
    Thankyou
  10. #10
    Newbie level 2
    Points: 17, Level: 1
    Join Date
    Mar 2013
    Posts
    Points
    17
    Level
    please send circuit diagram
    •   Alt12th March 2013, 10:39
      advertising
  11. #11
    Newbie level 5
    Points: 71, Level: 1
    Join Date
    Mar 2013
    Posts
    10
    Points
    71
    Level
    Gm sir,
    my name is nitin.
    I am working on the same thing but initially I want to convert 415v AC to 700 dc for the rectifier circuit. I have tried this circuit using IGBT circuit using two pole in Simulink matlab.
    but I am failing to do so why I don't know.my parameters and specification of the Simulink model is
    Vin = 415V(ac),Vout =700(dc).I have used feedback path to control the output regulated to 700.
    I have used PWM (4000hz) to drive first two igbt and next two igbt with the same frequency of the input voltage ie 50 hz.
    I have used PI(proportional integral) controller. but I don't know how to tune that PI controller.
    I am new to Simulink.
    please help I will be thankful to you.
  12. #12
    Full Member level 3
    Points: 1,831, Level: 9
    irfan ahmad's Avatar
    Join Date
    Feb 2012
    LAHORE PAKISTAN
    Posts
    181
    Points
    1,831
    Level
    9
    1) Ractify and filter the line voltage.
    2)Make a 3 phase oscillator .
    Click image for larger version.
    3) Make a power amplifier section .
