specialedster
Newbie level 2
I have a sampled sine wave of a 10kHz signal. It was sampled at 1Msps (1Mhz) so there is 100 samples per period. The total vector is 1024 samples long so its just over 10 periods total.
I have measured the THD of the analog signal using the fft function of a tektronix scope and I know the correct THD to be less than 1%. However, when I try to do this using MATLAB I am not getting the correct results and I expect this is because I am doing it incorrectly. I have pasted my current script below in hopes that somebody would be able to tell me what I am doing wrong. Thanks in advance!
%Use fft to find harmonics
harmonics = abs(real(fft(data))).^2;
%Assume the fundamental frequency is the highest
fundamental_bin = min(find(harmonics==max(harmonics)));
fundamental_power = harmonics(power_bin);
%Find the sum of the rest of the harmonics
harmonics_power = sum((harmonics((2:numHarmonics).*fundamental_bin)));
%Calculate THD as a ratio of square roots of powers
THD = 100*sqrt(harmonics_power)/sqrt(fundamental_power);
When I run this script I get a THD of over 8%, which as I explained earlier is far too high. Can anyone point me in the right direction or give me an example of someone who has done this correctly?
