[SOLVED] picking nmos switch to opperate at low control voltage
eanema
Member level 2
I have a hall device that operates at 3.0v with a CMOS output. Its data sheet says that its output control voltage can swing from gnd+0.4v to vdd-0.4v, so 0.4v -> 2.6v.
This device is a low power component that will be used to switch on and off the power of the main circuit. See the schematic below.
The problem I am having is finding a suitable NMOS device that can be switched fully on and fully off by the 0.4->2.6v swing. I've been looking at digikey and there doesn't *seem* to have a category for this type of parameter.
Any and all suggestions would be appreciated
thanks for the input, this device looks promising. The current should be ~<1A.
I am wondering, from reading the data sheet, how can I estimate Ids when Vgs=0.4v? The data sheet provides the info for when Vgs=0
Zero Gate Voltage Drain Current: Vds = 16v, Vgs = 0v => Ids=1 mA
thanks for you help
According to the datasheet the min Gate Threshold Voltage is 0.4v so you may have a small current at that level,
maybe you can try with a diode (or 2 diodes connected in the opposite direction to each other for charge/discharge) to drop the voltage to the gate about 0.6v, this will leave 0v when off and 2.6-0.6=2v when on
Alex
---------- Post added at 02:23 ---------- Previous post was at 02:13 ----------
If you use the diode(s) you should also add a resistor from the gate to the gnd to discharge the gate to 0 because one diode will not discharge the gate at all
and if there is a second diode in reverse it will only discharge the gate to about 0.6v.
Alex
Reactions: eanema
    eanema
Ah, very nice solution
thanks
