Broadband Antenna 1.9 to 2.2 GHz
bguk80
Newbie level 6
Greece
Hi
People i need some help and papers with an antenna design
I am looking for an antenna with 14% bandwith using slots or stacked patches, aperture coupling or any other succesful method to increase the bandwith. The dimensions should be less than 4cm*4cm
The Frequency should satisfy the IMT2000 Creterion which must cover the frequency range from 1.9 GHz to 2.2 GHz at least
I need to mention that the design should not include air substrate.
So far i have design something but dimension are greater and i need to minimum specification which is 4*4
regards and thanks in advanced
Hi bguk80
just have what you need. fill it with dialectric it will work.
RGZ
PL
