+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Member level 1
    Points: 522, Level: 4
    Join Date
    Dec 2010
    Posts
    41
    Points
    522
    Level
    Difference between Baud Rate and Bit Rate
    I would like to know the difference between baud rate and bit rate. And is there any formula relating to both variables that I can use to convert from baud rate to bit rate and vice versa? If for example my project needs a 1200 bps, what is the baud rate I need for my transmitter?
    Thanks.
    Regards.
  2. #2
    Super Moderator
    Points: 25,530, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,682
    Points
    25,530
    Level
    38
    Blog Entries
    Re: Difference between Baud Rate and Bit Rate
    There is not 1200 ???
    No sure if there exists difference.
  3. #3
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Bit rate is a measure of the number of data bits (that's 0's and 1's) transmitted in one second. A figure of 2400 bits per second means 2400 zeros or ones can be transmitted in one second, hence the abbreviation 'bps'.
    Baud rate by definition means the number of times a signal in a communications channel changes state. For example, a 2400 baud rate means that the channel can change states up to 2400 times per second. When I say 'change state' I mean that it can change from 0 to 1 up to 2400 times per second.
    " It is so simple to be happy,
    but it is so difficult to be simple"
    2 members found this post helpful.
    •   Alt16th February 2011, 13:13
      advertising
  4. #4
    Member level 1
    Join Date
    Dec 2010
    Posts
    41
    Points
    522
    Level
    when u said for baud rate it changes from 0 to 1, it does not include counting for 1 to 0 transition? so ur 2400 times per second is all from 0 to 1?
  5. #5
    Full Member level 3
    Points: 2,428, Level: 11
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    bit rate : no of bits transmitted per sec like 1200 bits transmitted in 1 sec
    baud rate: no of frames(1 or multiple bits ) transmitted per sec
    if u transmit 1 bit at a time then bit rate = baud rate
    if u transmit 2 bit at a time then bit rate = 2x baud rate and so on
  6. #6
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    bit rate will be equal or more than baud rate.... baud rate can never be more than bit rate...
  7. #7
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,682
    Points
    25,530
    Level
    38
    Blog Entries
    Quote Originally Posted by andre_teprom View Post
    So, answering the question, there is no difference, wright ?
    •   Alt16th February 2011, 13:37
      advertising
  8. #8
    Member level 1
    Join Date
    Dec 2010
    Posts
    41
    Points
    522
    Level
    okay, I am a little confused. cause in my situation now I am suppose to get a 1200 bps signal but the computer program which i am going to use to generate the signal only allows me to key in baud rate. so i planning to transmit a periodic signal of 4 binary '1' bits followed by 4 binary '0' bits and so on. And this periodic signal includes a start and stop bit in the packet.
  9. #9
    Member level 1
    Points: 897, Level: 6
    Join Date
    Jan 2011
    Posts
    38
    Points
    897
    Level
    baud rate can be seen as number of symbols per second. I.e say you have 8 symbols . In binary you need 3 bits to represent 8 symbols. 000 to 111. Now, if a system can transmit 8 symbols in one second you say baud rate is 8 and equivalent bit rate is 24 bit/sec (8X3).
  10. #10
    Administrator
    Points: 37,969, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    Quote Originally Posted by fouwad View Post
    Quote Originally Posted by ckshivaram View Post
    i think he means that when bit rate is 1000 then boud rate will be 1000/2=500 , he just wrote it the wrong way.
    500 frames (baud rate) , each 2 bit, =1000 bps (bitrate)
    Actually what he wrote is correct, bitrate will be twice the baudrate for 2 bit transition
    Alex
  11. #11
    Full Member level 2
    Points: 2,452, Level: 11
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    132
    Points
    2,452
    Level
    11
    Bit Rate: Number of bits transmitted per second(as stated above).
    Baud rate: It is measurement of the number of times per second a signal in a communication channel chages it state. e.g, 2400 baud rate means that signal in a channel can change states upto 2400 times per second.
    Relation between Bit rate and baud rate: bps(bits per second)= Baud per second * Number of bits per baud(It ll be determined by the modulation technique used)
    Use this relation and do not forget to take care of modulation technique used(bpsk,qpsk and so on) and you ll always go back and forth from bit rate to baudrate successfully. Examples given above holds true according to the relation mentioned.
    In your specific case:
    you need 1200bps and you r transmitting 4bits(1,s or o,s) per baud so your baud rate ll be
    1200/4= 300 baud rate
    Hope it helps.
    /SC
  12. #12
    Points: 10,476, Level: 24
    Achievements:
    7 years registered
    tony_lth's Avatar
    Join Date
    Jul 2010
    Beijing
    Posts
    1,927
    Points
    10,476
    Level
    24
    It's relate to modulation scheme.
    Say:
    For QPSK, spectrum effiency is 2bit/s/Hz, so Baud rate is bps/2.
    For 16QQAM, spectrum effiency is 4bit/s/Hz, so Baud rate is bps/4.
    For 128QQAM, spectrum effiency is 7bit/s/Hz, so Baud rate is bps/7.
    1 members found this post helpful.
  13. #13
    Member level 1
    Join Date
    Dec 2010
    Posts
    41
    Points
    522
    Level
    Quote Originally Posted by tony_lth View Post
    Say:
    Hi, thanks for all the reply. If I am using AFSK?
  14. #14
    Achievements:
    7 years registered
    tony_lth's Avatar
    Join Date
    Jul 2010
    Beijing
    Posts
    1,927
    Points
    10,476
    Level
    24
    For AFSK, spectrum effiency is 1bit/s/Hz, so Baud rate = bps.
    For 4FSK, spectrum effiency is 2bit/s/Hz, so Baud rate is bps/2.
    •   Alt17th February 2011, 23:16
      advertising
  15. #15
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    May 2013
    Posts
    Points
    13
    Level
    Quote Originally Posted by Wql View Post
    Thanks.
    Regards.
    there is no difference between bit rate and baud rate.. there fore the answer is 1200
