+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Points: 355, Level: 4
    Join Date
    Feb 2011
    Posts
    Points
    355
    Level
    dsPIC30f4011 sinusoidal PWM generation
    i'm trying to do my project by using dsPIC30f4011 to generate 5kHz 3 phase sine wave with PWM module. inputs are 2 variable voltage (0-5V) into ADC module then change float to integer and generate ramp signal to find the angle of input value then use park (Iα,Iβ»Id,Iq) and inverse clarke (Id,Iq»Ia,Ib,Ic) transform to get 3 phase signal and send to PWM module. it will gets 3 pulse signals. Finally, put signals to i2c module to connect with DAC converter.
    Is my idea OK?
    can anybody give me idea or sample code.
    Regard
  2. #2
    Advanced Member level 5
    Points: 12,648, Level: 26
    Achievements:
    7 years registered
    Join Date
    Nov 2008
    Norwich, UK
    Posts
    2,122
    Points
    12,648
    Level
    26
    Re: dsPIC30f4011 sinusoidal PWM generation
    In the past I used a MCP4101 digital pot which has an SPI interface to generate sine waves of approx 2KHz
    MCP41010
    not sure if it would work at 5KHz but worth considering
    the alternative is a DAC - for example I used Integra development boards with Texas DSP processors and high speed DACs to generate frequencies of 1 to 10 MHz
    •   Alt15th February 2011, 11:50
      advertising
  3. #3
    Join Date
    Feb 2011
    Posts
    Points
    355
    Level
    thanks for reply
    Now, I have problem about Qmath (it's use in changing float to integer), i don't know to write code in C.
    can you give me some example code.
    thank you very much
  4. #4
    Achievements:
    7 years registered
    Join Date
    Nov 2008
    Norwich, UK
    Posts
    2,122
    Points
    12,648
    Level
    26
    it depends on what you are trying to do, e.g. the range of float values and what size integer you are converting too.
    e.g. if you are driving a 12bit DAC (range -2048 to +2047 ) from a sine function (range -1.0 to +1.0) you could do something like
       int DACvalue= (int) (2047.0 * sin(angle));
    •   Alt15th February 2011, 13:38
      advertising
  5. #5
    Join Date
    Feb 2011
    Posts
    Points
    355
    Level
    My inputs are 2 voltage values (vary 0-5V) into 10 bit ADC , i want to change these inputs from float to integer for taken to use in park transform calculation.
    can you give exam code and some advice for me
    thank for advance
  6. #6
    Achievements:
    7 years registered
    Join Date
    Nov 2008
    Norwich, UK
    Posts
    2,122
    Points
    12,648
    Level
    26
    a 10bit ADC would give output 0 to 1023 or -512 to 511 for the full range input depending on how it is set up.
    Assuming 0 to 1023 - 0 volts would be represented by 0 and 5 volts by 1023 so conversion from ADC value to a float voltage would be
       float voltage = 5.0f* ADCvalue / 1023.0f;
    would give you a value in the range 0 to 5.0
  7. #7
    Join Date
    Feb 2011
    Posts
    Points
    355
    Level
    your post has useful for me.
    I will do follow your advice, thank you very much.
    At this moment,i use i2c module to connect ADC converter
    can anyone give me some code and idea.
    reguard
  8. #8
    Achievements:
    7 years registered
    Join Date
    Nov 2008
    Norwich, UK
    Posts
    2,122
    Points
    12,648
    Level
    26
    any particular reason why you are not using the ADC of the dsPIC30f4011 ?
    here is some sample code to drive the I2C interface of a PIC24 (the dsPIC should be similar)
    // i2cFunctions.c - to drive I2C2 interface
    #define USE_AND_OR
    #include "i2c.h"
    #include "Hardware.h"
    #include "stdio.h"
    #include "timer.h"
    static int I2C2address=0; 		// address of I2C2 device
    //    This routine is used to write a byte to the I2C2 bus. The input parameter data_out is written to the
    //    I2C2TRN register. If IWCOL bit is set,write collision has occured and -1 is returned,
    //    if acknowledge timeout return -2, else 0 is returned.
    char MasterWriteI2C2(const unsigned char data_out)
        I2C2TRN = data_out;						// write data byte
        if(I2C2STATbits.BCL)
           { printf("I2C Master bus collision detect %0x\n", I2C2STAT); return -1; }        /* If write collision occurs,return -1 */
        if(I2C2STATbits.IWCOL)
           { printf("I2C write collision detect %0x\n", I2C2STAT); return -1; }        /* If write collision occurs,return -1 */
        int timeOutCount=10000;
        while(I2C2STATbits.TBF || I2C2CONbits.SEN || I2C2CONbits.PEN || I2C2CONbits.RCEN || I2C2CONbits.ACKEN || I2C2STATbits.TRSTAT || I2C2STATbits.ACKSTAT)
           if(!timeOutCount--) { printf("\n\rMasterWriteI2C2 address %#x timeout config %#x status %#x \n\r", I2C2address, I2C2CON, I2C2STAT);	return -2; }
        //    printf(" %0x ", I2C2STAT);
        return 0;
    //  This routine is used to write out an array to the
    // I2C2 bus.If write collision occurs,-3 is sent.If
    //  Nack is received, -2 is sent.If arrayis written 0 is returned.
    static unsigned int MasterPutArrayI2C2(const unsigned char * wrptr, int count)
        int i=0;
        while(count--)                           //transmit data
            if((i=MasterWriteI2C2(*wrptr)) < 0) return i;	    // write a byte - return on error
            wrptr++;
        return 0;
    // write to I2C2 address array wrptr of length, if sendStop is 1 send a STOP at end
    int writeI2C2(const int address, const unsigned char *wrptr, int length, int sendStop)
       unsigned int i2cbrg=((SYSCLK/100000L)-(SYSCLK/1111111L))-1;	/* Baud rate is set for 100 Khz */
       unsigned int config1 = (I2C_ON | I2C_IDLE_CON | I2C_CLK_HLD	/* Configure I2C for 7 bit address mode */
         | I2C_IPMI_DIS | I2C_7BIT_ADD   | I2C_SLW_DIS | I2C_SM_DIS |
         I2C_GCALL_DIS | I2C_STR_DIS |   I2C_NACK | I2C_ACK_DIS | I2C_RCV_DIS |
         I2C_STOP_DIS | I2C_RESTART_DIS  | I2C_START_DIS);
       // problem with Master bus colision on PIC24s, see
       //   http://forum.microchip.com/tm.aspx?m=271183&mpage=1&key=
       TRISAbits.TRISA3=0;
       LATAbits.LATA3 = 0;   //where LATBx = the SDAx pin
       LATAbits.LATA3 = 1;
       OpenI2C2(config1,i2cbrg);									/* open the I2C2 device */
       //printf("\nwrite I2C2 %#x %0x %0x I2C stat %0x \n", address,config1,i2cbrg,I2C2STAT);
       IdleI2C2();
       StartI2C2();												/* send START */
       while(I2C2CONbits.SEN );									/* Wait till Start sequence is completed */
       if(MasterWriteI2C2(I2C2address=address) < 0) return -1;	/* Write Slave address and set master for transmission */
       if(MasterPutArrayI2C2(wrptr, length) < 0) return -1;		/* Transmit string of data */
       if(!sendStop) return 0;
       StopI2C2();												/* send STOP */
       while(I2C2CONbits.PEN);									/* Wait till stop sequence is completed */
       CloseI2C2();
       return 0;
    // read from I2C2 device address
    // initially send tx_data (length tx_length), restart and read rx_length bytes into rs_data
    int readI2C2(int address, unsigned char *tx_data, int tx_length, unsigned char * rx_data, int rx_length)
       //int i;
       unsigned int i2c_data_wait= 11152;
       //printf("\n\rread I2C2 %#x ", address);
       writeI2C2(address,tx_data, tx_length, 0);		// send address and register number etc
       RestartI2C2();     							// send RESTART ready for a read!
       while(I2C2CONbits.RSEN );						// wait for restart complete
       if(MasterWriteI2C2(address+1)<0)return -1;	/* Write Slave address and set master for read */
       if(MastergetsI2C2(rx_length, rx_data, i2c_data_wait)!=0)return -1;	// read data from slave
       // uart2_puts("\n\rread  ");
       // for(i=0;i<rx_length;i++) { printHex(rx_data[i],uart2_putchar); uart2_putchar(' ');}
       StopI2C2();									/* send stop */
       CloseI2C2();									// close I2C2 device
       return 0;
    I appeared to use it for reading the EUI-48 node address from a Microchip 24AA02E48 serial EEPROM
    // read 24AA02E48 serail EEPROM with EUI-48 node identy
    int read24AA02E48MACaddress(void)
       // MAC address is at EPROM address FAhex
       unsigned char data[10] ={0xfa}, check[3]={0, 0x4,0xa3};						// read from 0xfa
       int i;
       printf("read 24AA02E48 serail EEPROM with EUI-48 node identy\n");
       readI2C(address, data, 1, data, 6);		// read 6 bytes
       // if node ID does not exist return otherwise set it up
    •   Alt15th February 2011, 19:13
      advertising
  9. #9
    Join Date
    Feb 2011
    Posts
    Points
    355
    Level
    thank you very much for your reply,
    i will taken to apply in my project.
