+ Post New Thread
Results 1 to 5 of 5
10th February 2011, 06:10 #1
- Join Date
- Feb 2011
- Location
- Bangalore
- Posts
- 41
- Helped
- 3 / 3
- Points
- 535
- Level
- 4
Allegro PCB editor importing..
Hi mate,..
I have generated the netlist for allegro (5 schematic pages ) using orcad capture. that is, having three dat files.. As a next step, i am tried to import the netlist into allegro PCB editor. It just showing the blank page after importing also. The path i used is file--> import --> logic --> cadence --> import cadence.
Can u please clarify that what may be the problem.. Thank u so much...
Yrs,...
Prince Moses,
Chennai.
10th February 2011, 11:45 #2
- Join Date
- Jan 2005
- Location
- Nice, France
- Posts
- 159
- Helped
- 39 / 39
- Points
- 3,448
- Level
- 13
Re: Allegro PCB editor importing..
Hello,
First you have to draw your board shape (board geometry/outline).
If you don't have any error message during the netlist importation, you can go to place-->manually and then pick your components and place them on your PCB.
There is also automatic method to place component (around the board for example).
Regards,
Franck.I changed my nick from crevars->elec4fun
1 members found this post helpful.
10th February 2011, 17:33 #3
- Join Date
- Dec 2010
- Location
- Bangalore
- Posts
- 17
- Helped
- 10 / 10
- Points
- 492
- Level
- 4
Before you importing in to boardfile set correct library path,Setup ->User preference->Paths->Library ,select path for both pad and psm paths.Then draw outline and import into board file.Then Place->Quick place.If no errors or warnings all components will come inside.
11th February 2011, 08:05 #4
- Join Date
- Feb 2011
- Location
- Bangalore
- Posts
- 41
- Helped
- 3 / 3
- Points
- 535
- Level
- 4
hi sir..
I thank u so much for yr help sir.. i did as u told.. the problem i faced now is that the board outline that i made initially is not sufficient to have all my components(160). Is there any way to edit the size of outline?.. how to do sir??
Thank u so much.
Regards,
KP Moses, Chennai
---------- Post added at 12:35 ---------- Previous post was at 12:23 ----------
Hi mate...
I thank u so much for ur support by replying to my question.. the problem i am facing now is that the board outline that i made initially is not sufficient to have all my components while placing components(160). Is there any way to reedit the size of outline?.. how to do sir?? how can i predict the size of outline initially???
Thank u so much.
Regards,
Prince, Chennai(kprincemoses@gmail.com)
11th February 2011, 17:23 #5
- Join Date
- Dec 2010
- Location
- Bangalore
- Posts
- 17
- Helped
- 10 / 10
- Points
- 492
- Level
- 4
Hi Prince,
Use Edit vertex command and extend outline for required value.
+ Post New Thread
Please login
