how to send Sms using GSM module for LPC2378?
nagarajanj21
Member level 1
Chennai, INDIA
Hai need a coding for to send sms. i am using LPC2378 microcontroller. please help me...
thanks in advance
you need to send AT commands through serial port and read its response from the same port ... you can write the code and test controller is working or not by connecting controller board to hyperterminal... later connect modem to it
check your program on the simulator if the program responds to the response you type in serial window. then it will be easy for you.. later check GSM modem on terminal and then connect both.......
