The use of capacitors in regulator 7805
bramin19
Member level 1
The regulator 7805 is having 2 capacitors at input side and also on output side. can any one explain the use of these capacitors?
can i connect the input without these capacitors for having right output?
Thanks in advance.
Re: enquiry on Regulator
You should always connect a capacitor of more than 100nF and preferably in the region of 1 to 10uF across the input terminal and ground with the wiring as short as possible. A capacitor on the output is less important but it is preferable to have one close to the output and ground pins as well. If you make the output capacitor too big, it has a detrimental effect on the regulators transient response.
Smoothing is performed by a large value electrolytic capacitor connected across the DC supply to act as a reservoir, supplying current to the output when the varying DC voltage from the rectifier is falling. The diagram shows the unsmoothed varying DC (dotted line) and the smoothed DC (solid line). The capacitor charges quickly near the peak of the varying DC, and then discharges as it supplies current to the output.
Note that smoothing significantly increases the average DC voltage to almost the peak value (1.4 × RMS value). For example 6V RMS AC is rectified to full wave DC of about 4.6V RMS (1.4V is lost in the bridge rectifier), with smoothing this increases to almost the peak value giving 1.4 × 4.6 = 6.4V smooth DC.
Smoothing is not perfect due to the capacitor voltage falling a little as it discharges, giving a small ripple voltage. For many circuits a ripple which is 10% of the supply voltage is satisfactory and the equation below gives the required value for the smoothing capacitor. A larger capacitor will give less ripple. The capacitor value must be doubled when smoothing half-wave DC.
There is more information
about smoothing on the
Electronics in Meccano
website.
Smoothing capacitor for 10% ripple, C = 5 × Io
Vs × f
C = smoothing capacitance in farads (F)
Io = output current from the supply in amps (A)
Vs = supply voltage in volts (V), this is the peak value of the unsmoothed DC
f = frequency of the AC supply in hertz (Hz), 50Hz in the UK
At the least, one capacitor is needed for input and another cap is needed for output. That is basic for stability of 7805.
Some additional small capacitor will filter high frequency noise. However, it can be deleted if there is no low noise requirement.
However some new LDO can be stable without input/output cap.
Thanks in advance.
