+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Points: 380, Level: 4
    Join Date
    Dec 2010
    Posts
    Points
    380
    Level
    Problem while programming AT89C2051
    Hlo, everyone
    I am a beginner in this programming stuff I had recently made a line follower robot to make which work i have to program a microchip I have taken the circuit from here :- Line Follower Robot
    I even had attended a workshop at my school where those people gave me the programmer for at89c51 whose name shown on my pc is "Silicon Labs 210x USB to UART Bridge". While researching I found a software ie proload 1.4 which when I used detected the development board but not the chip it shows "Device Programmer for 89 Series 4.4 SS Chip Not Detected 0 bytes used" .In one of the pages(Atmel 89 Series Flash Programmer Ver 3.0) I saw that an adapter could make it work for 20pin chips even will it be true for my development board also..?? and would the circuit for the adapter remain same..??
    And yeah I want to program AT89C2051.
    Plz help me..
    Thanx..
  2. #2
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Re: Problem while programming AT89C2051
    which programmer are you using to program your chip... proload is the software but which paegrammer you are using
    " It is so simple to be happy,
    but it is so difficult to be simple"
    •   Alt28th January 2011, 04:13
      advertising
  3. #3
    Join Date
    Dec 2010
    Posts
    Points
    380
    Level
    I told ya Silicon Labs 210x USB to UART Bridge
  4. #4
    Advanced Member level 2
    Points: 6,597, Level: 19
    ctownsend's Avatar
    Join Date
    Nov 2004
    Canada
    Posts
    573
    Points
    6,597
    Level
    19
    Silicon Labs 210x USB to UART Bridge refers to the USB to UART device and driver your programmer is using, it does not explain anything about the programmer or circuit you are using. To program 89C2051 you need a 12V circuit for the reset pin. This mcu only can be programmed in parallel mode.
    Why not use another mcu that can be programmed with ISP? (89S2051, 89S51)
    Do some research and you will learn. There are many websites with information on building one of these programmers.
  5. #5
    Banned
    Points: 558, Level: 5
    Join Date
    Jan 2011
    bangalore
    Posts
    39
    Points
    558
    Level
    Silicon Labs 210x USB to UART Bridge is not the programmer its driver for usb to serial cable.... as ckshivaram said. you never told what external hardware device you are using for programming the controller
    •   Alt28th January 2011, 14:57
      advertising
  6. #6
    Join Date
    Dec 2010
    Posts
    Points
    380
    Level
    http://nskelectronics.com/usb_8051_programmer.html
    this is it this is the programmer i am using
    Could anyone plz give a link for proload 4.1 plz
  7. #7
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    1 members found this post helpful.
  8. #8
    Join Date
    Dec 2010
    Posts
    Points
    380
    Level
    I tried the adapter but in vain
    Guyz isnt there a way other than to buy a new programmer..??
  9. #9
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    Did you buy an seperate adaptor for 20 pin IC for that programmer board???????
    •   Alt29th January 2011, 11:06
      advertising
  10. #10
    Join Date
    Dec 2010
    Posts
    Points
    380
    Level
    no ii made it myself
  11. #11
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    Quote Originally Posted by rohanz View Post
    Then i deeply suspect the adaptor connection errors. Try programming a 89C52 with the same programmer and it shud work well. Cheers
