Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Junior Member level 3
    Points: 497, Level: 4
    Oct 2010
    26
    497
    How to create lookup table for sin(4(pi)x) in VHDL?
    hi,
    how to create lookuptable for sin(4(pi)x) and cos(20(pi)x) in VHDL, The x range is -4 :1/32:4... i.e., 256 values..Anyone help me...
    Full Member level 5
    Points: 3,271, Level: 13
    amitjagtap's Avatar
    Jan 2007
    304
    3,271
    13
    Re: How to create lookup table for sin(4(pi)x) in VHDL?
    Mostly MATLAB is used in such cases.....you write a simple MATLAB code to get these sin & cos values then in Xilinx (hope you are using xilinx) instantiate LUT or Block RAM to store these values.
    "Doubt grows with knowledge."
    "The best way to have a good idea is to have a lot of ideas"....Linus Pauling
    •   Alt25th January 2011, 08:42
      advertising
    Points: 239,566, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    One possible way is to calculate the table in VHDL at compile time, as shown in the below example. (It's a 0..pi sine table, not the solution for your problem).
    TYPE SINTAB IS ARRAY(0 TO ROMSIZE-1) OF STD_LOGIC_VECTOR (NNCO-2 DOWNTO 0);
    SIGNAL SINROM: SINTAB;
    BEGIN
    GENROM:
    FOR idx in 0 TO ROMSIZE-1 GENERATE
    	CONSTANT x: REAL := SIN(real(idx)*MATH_PI/real(ROMSIZE));
    	CONSTANT xn: UNSIGNED (NNCO-2 DOWNTO 0) := CONV_UNSIGNED(INTEGER(x*real(ROMMAX)),NNCO-1);
    BEGIN
    	SINROM(idx) <= STD_LOGIC_VECTOR(xn);
    END GENERATE;
    Points: 35,434, Level: 45
    Jun 2010
    6,485
    35,434
    45
    Why not do similar to FvM's idea, but do the setup inside a function, that way you can assign a constant instead of a signal.
    Also, have a look into the fixed point packages so you dont have to keep remembering where the fractional bits are when you store the values in an unsigned.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    A function is possibly the more flexible way, and doesn't rely on rarely used VHDL constructs that are mostly ignored by text books.
    The difference between a signal and a constant doesn't matter for the actual LUT implementation. My example will usually cause ROM inference, when supported by the respective hardware, and not explicitely prohibited in the compiler settings, and a LUT in logic cells otherwise. The same can be expected for a functions supplying constant values.
    You don't necessarily need a full fixed point package, but you should understand how the sine range of -1.0 .. + 1.0 can be represented by integer numbers. It's mostly a question of your overall design, what the table values are used for.
    Oct 2010
    26
    497
    hi,
    Thanks for all ....
    ---------- Post added at 12:18 ---------- Previous post was at 12:09 ----------
    actually, the equation is f(x) = 21.5 + x sin(4πx) + x cos(20πx). the x range is -4 to +4, find the maximum value of this equation ...The maximum value is 28.25... shall write vhdl code for this equation ...is it posssible to show 28.25 in an output(xilinx)?
  7. #7
    Oct 2010
    26
    497
    sorry..How 28.25 represented in binary? what method use?
  8. #8
    Jun 2010
    6,485
    35,434
    45
    You can use whatever representation you want - usually people stick with floating or fixed point. You could use that equation to generate a look up table in VHDL quite easily, but you have to decide if you want fixed point or floating point for the output. The input (X) will have to be fixed point.
  9. #9
    Oct 2010
    26
    497
    Quote Originally Posted by TrickyDicky View Post
    is it possible to do in floating point for both input and output?
    •   Alt1st February 2011, 12:02
      advertising
  10. #10
    Jun 2010
    6,485
    35,434
    45
    Output yes.
    Input - you cannot do full precision (32 bit) floating point as this would require a 4GB look up table. You can reduce exponent and mantissa width to something more sensible to reduce the look up table size (total max 20 bits on large expensive FPGA devices). But generally, no. Its easier to stick with fixed point.
    •   Alt1st February 2011, 12:06
      advertising
  11. #11
    Oct 2010
    26
    497
    In theroetically, for input X= -3.6563 coresponding to output y is 28.25..How is show this output in xilinx and FPGA KIT?
    ---------- Post added at 12:38 ---------- Previous post was at 12:29 ----------
    is it possible in VHDL?
  12. #12
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    It seems to me, that a 8-Bit fixed point representation is already suggested by the exercise text, e.g. 3.5 for x and 6.2 for y. The objective is apparently to show the principle method, not to achieve high accuracy.
  13. #13
    Jun 2010
    6,485
    35,434
    45
    both values can easily (or very closly) be represented in 8 bit fixed point.
  14. #14
    Oct 2010
    26
    497
    ok.. for x is -1 and 1 ..the value of sin(4(pi)x) is '0'...sinn(pi)is '0'.for all value of x ..sin value '0'.. then how proceed?
  15. #15
    Jun 2010
    6,485
    35,434
    45
    create a look up table.
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    A fixed point table for sin(4 pi x) with 8 bit fixed point signed values would look like this
    xi     x   sin(4pi x) sin_4pix_i
    -128 -4.000  0           0
    -127 -3.969  0.098      13
    -112 -3.500  1.000      127 (saturated)
    -1   -0.031 -0.098     -13
    0     0.000  0.000       0
    +127  3.969 -0.098     -13
    If not utilizing VHDL to calculate it, as previously suggested, use a spread sheet calculator.
  17. #17
    Oct 2010
    26
    497
    How did calculate? how did take range?
  18. #18
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,505
    239,566
    100
    The scaling for x is already suggested in the original post. The y scaling is obvious by the sin() range.
  19. #19
    Newbie level 5
    Points: 423, Level: 4
    Nov 2010
    10
    423
    Here is how I do it using Python to generate the table, using an initialized Xilinx RAM64X1S to hold the values. It is in Verilog, but converting it to VHDL should be easy.
    RAM64X1S as a sine wave ROM
    •   Alt5th February 2011, 18:55
      advertising
  20. #20
    Oct 2010
    26
    497
    Thanks..How to convert -3.9688 into 8-bit binary number?
