Tracking Time and how to deal with Real Time Clock for CCS?
dani
Full Member level 4
UK
Tracking Time...
Hi all,
To track time for a specified task..where some function purely based on elapsed time and accuracy of time is also criticle, is external RTC with PIC microcontroller is more suit able or interuppt driven time calculation is sufficient for this task...
Please share ideas based on experiences....
Re: Tracking Time...
Facing this kind of problem, I founded two solutions :
1) Activation/desactivation of a port at the begin/end of the task or isr routine an mesuring the elapsed time with a scope.
2) Use a timer. By reading it at the begin of the task / isr and reading again at the end. Knowing the clock frequency the timer is feeded with gives the elapsed time value.
For both solution, add the time neeged to do these operation by reading the asm code and counting the instruction cycles, can improve the accuracy of the result.
Does anybody have idea how to deal with Real Time Clock for CCS compiler? Thanks!
CCS code for RTC interfacing
There are example codes available to interface realTime Clock Chips which you can find with the installation of CCS Compliler. Or otherwise you can search your solution at CCS forum or Technocrafts Forum.
Links are
www.technocrafts.com/forum
www.ccsinfo.com/forum
Or if you need some specific thing you can ask.
