+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 3
    Points: 3,272, Level: 13
    roger's Avatar
    Join Date
    Aug 2003
    Posts
    163
    Points
    3,272
    Level
    13
    vhdl srl
    when I use SRL,ROR,... operator in VHDL
    modelsim5.8sb shows
    # ** Error: ./rtl/SPI_Model.vhd(136): No feasible entries for infix op: "srl".
    # ** Error: ./rtl/SPI_Model.vhd(136): Type error resolving infix expression.
    # ** Error: ./rtl/SPI_Model.vhd(146): VHDL Compiler exiting
    # ** Error: C:/Modeltech_5.8b/win32/vcom failed.
    which package should I add,
    I have added
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_unsigned.all;
    use ieee.numeric_std.all;
    but failed
    •   Alt18th June 2004, 08:14
      advertising
  2. #2
    Full Member level 1
    Points: 2,153, Level: 10
    gerade's Avatar
    Join Date
    May 2004
    the hole eletron left behind
    Posts
    109
    Points
    2,153
    Level
    10
    vhdl shr
    there are not such operation in VHDL, i think
    what VHDL has in ieee.std_logic_arith is
    shl shr
    which can be use for signed or unsigned number
    and in ieee.numeric_bit
    there are shift_left/shift_right
    rotate_left/right
    regards
  3. #3
    Full Member level 3
    roger's Avatar
    Join Date
    Aug 2003
    Posts
    163
    Points
    3,272
    Level
    13
    srl vhdl
    a reference book named "HDL Chip design" by Douglas J Smith
    page 69 contains SLL SRL operator example,but it contains
    ieee.numeric_std.all, I wondwr if the examples of the chapter
    are executable
  4. #4
    Full Member level 3
    roger's Avatar
    Join Date
    Aug 2003
    Posts
    163
    Points
    3,272
    Level
    13
    vhdl ror
    Quote Originally Posted by gerade
    shl shr
    rotate_left/right
    regards
    I did add this package but still shows the same message!
    What's wrong with my modelsim or something?
  5. #5
    Full Member level 2
    Points: 3,509, Level: 13
    Join Date
    Jun 2002
    Posts
    148
    Points
    3,509
    Level
    13
    ror vhdl
    You include too many packages. All three packages are mutually exclusive. You should use numeric_std only, and have a look at the operators defined for numeric_std, in section 2 of
    http://www-lsi.die.upm.es/~marisa/docencia/1164pkg.pdf
    The VHDL spec says that if two different definitions are imported from packages, they destroy each other.
    •   Alt27th June 2004, 10:54
      advertising
  6. #6
    Full Member level 3
    roger's Avatar
    Join Date
    Aug 2003
    Posts
    163
    Points
    3,272
    Level
    13
    vhdl srl example
    I add only
    library ieee;
    and founf`d the same condition , why?
  7. #7
    Full Member level 3
    Points: 2,453, Level: 11
    Join Date
    Jun 2004
    India
    Posts
    155
    Points
    2,453
    Level
    11
    shr vhdl
    Instead of all these difficulties...
    u can use simple logic like...
    if u want to do left shift.. then say ur signal is of 8 bit vectors.. and ur inoput is single bit then..
    outdatareg(7 downto 1) <= indatareg(6 downto 0);
    indatareg(0) <= indata;
    like this u can implement left or rigth shift opreations...
    jay
  8. #8
    Full Member level 3
    roger's Avatar
    Join Date
    Aug 2003
    Posts
    163
    Points
    3,272
    Level
    13
    vhdl sll example
    Quote Originally Posted by jay_ec_engg
    jay
    I know it's not difficult to do that. but just curious such kind
    of common operator cannot be done, I never found similar
    problem in verilog. How can I love VHDL more?
    •   Alt29th June 2004, 15:37
      advertising
  9. #9
    Newbie level 3
    Points: 1,534, Level: 8
    Join Date
    Jun 2004
    Posts
    Points
    1,534
    Level
    8
    vhdl sll
    Is it a problem of VHDL version? '87 or '93.. juz change the option and see.
  10. #10
    Full Member level 3
    Join Date
    Jun 2004
    India
    Posts
    155
    Points
    2,453
    Level
    11
    sll vhdl
    Its problem of VHDL'93....
    ALTERA is not supporting all the features of IEEE93 standards.....
    u cant use some good fuinctions which they are saying " IT WILL WORK with 93 version"... dont know about xilinx or otehr tools
    jay
  11. #11
    Full Member level 3
    Points: 3,645, Level: 14
    Join Date
    Jul 2002
    Posts
    156
    Points
    3,645
    Level
    14
    shl vhdl
    Roger,
    I think you're problem might be that you're not passing the SRL function a data type that it recognizes. I believe it only supports bit vectors. If you want to use a std_logic_vector you would have to do something like:
    to_stdlogicvector(to_bitvector(wrptr2) srl i)
