Fully differential OPAMP slew rate simulation and monte carlo analysis
juliog
Newbie level 6
Hello guys,
How can I cancel the offset produced by transistor mismatches (monte carlo analysis) to measure the slew rate (trans analysis)? I want the offset to be cancelled for each iteration of the monte carlo analysis, but of course i cannot calculate the input-referred offset... it's different for each iteration and random.
Is it possible to do it with an open loop configuration?
Thanks!! :)
I think it is not easy to cancel the offset in the Monte Carlo Simulation. The component model has been changed to ***mc in the simulation. moreover, the offset is random for each iteration as you mentioned.
