+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 1
    Points: 1,239, Level: 7
    Join Date
    Aug 2010
    Malaysia
    Posts
    102
    Points
    1,239
    Level
    7
    How to build own transformer?
    Can anyone teach me how to wind the transformer myself. I need a mid-point transformer. For example, this is the core for the transformer.
    Ferrite,core,ungapped,EFD25/13/9,2000nH(AL),N87,B66421-G-X187
    •   Alt7th January 2011, 14:56
      advertising
  2. #2
    Advanced Member level 5
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    Re: How to build own transformer?
    Do you mean a transformer with a centre tapped primary? What do you want as a secondary? What frequency do you want to use it at and at what power level?
    Frank
  3. #3
    Full Member level 1
    Join Date
    Aug 2010
    Malaysia
    Posts
    102
    Points
    1,239
    Level
    7
    I want centre tapped secondary. The primary is 240V and each of the secondary is 17V. The input frequency is 50Hz and my mosfets are switching at frequency 20k Hz. So I need to get a SMPS transformer. The problem is I don't know how to choose and I don't know how to wind the transformer to become centre tapped.
  4. #4
    Join Date
    Dec 2010
    Posts
    4,863
    Points
    25,337
    Level
    38
    If you are going the standard SMPS route, the mains goes via a small resistor to a bridge rectifier and a smoothing capacitor, so the DC V available is 240 x 1.4 = ~ 350v, If your mains is 110V then its 160V DC. To make a centre tapped transformer, take twice the length of wire you need, fold it in half, wind the coil with this double wire. Snip the fold, label one wire "A" the other "B". find the other end of wire "A", twist this around wire labeled "B", this is your centre tap.
    Frank
  5. #5
    Advanced Member level 2
    Points: 3,868, Level: 14
    Join Date
    Aug 2010
    Posts
    554
    Points
    3,868
    Level
    14
    Sounds like you want a flyback transformer not a push-pull primary. That ungapped core is not suitable for a flyback arrangement.
    This link has good overall info on designing both types of SMPS.
    Fundamentals of Power Electronics Instructor's slides
    •   Alt9th January 2011, 01:39
      advertising
  6. #6
    Full Member level 1
    Join Date
    Aug 2010
    Malaysia
    Posts
    102
    Points
    1,239
    Level
    7
    Thanks chuckey. How much is the size of the wire for the transformer?? Do you have any idea where to get a readily made smps transformer?
    ---------- Post added at 07:00 ---------- Previous post was at 06:53 ----------
    Thanks RCinFla. But I need a mid point transformer not a flyback transformer. What is the difference between ungapped and gapped core?
  7. #7
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Here you can find a few guidelines on winding transformer with centre-tap: Switchmode Power Supply For Car Audio
    I think you should wind your own transformer according to your own requirements as you may not always find ready-made transformers that suit your requirements.
    Hope this helps.
    Tahmid.
    1 members found this post helpful.
  8. #8
    Full Member level 1
    Join Date
    Aug 2010
    Malaysia
    Posts
    102
    Points
    1,239
    Level
    7
    Hi Tahmid. Thanks for the site. It really helps me. Do you still have others to recommend? Such as calculations or formulas which I needed?
  9. #9
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    These are taken from Marty Brown's "Power Supply Cookbook":
    Npri = (Vinnom * 10^8) / (4 *f * Bmax * Ac)
    Nsec = [1.1(Vout + Vfwd)*Npri] / (Vinmin * DCmax)
    f - frequency in Hz
    Bmax - flux density in gauss (webers/cm^2)
    Ac - effective core cross sectional area (cm^2)
    Vfwd - diode forward voltage in V
    Npri - primary no. of turns
    Nsec - secondary no. of turns
    DCMax - maximum expected duty cycle (0-1), if you don't have a reference, 0.95 is good
    Hope this helps.
    Tahmid.
    •   Alt10th January 2011, 16:15
      advertising
  10. #10
    Full Member level 1
    Join Date
    Aug 2010
    Malaysia
    Posts
    102
    Points
    1,239
    Level
    7
    thanks, Tahmid~~
  11. #11
    Member level 3
    Points: 600, Level: 5
    Join Date
    Dec 2010
    Posts
    61
    Points
    600
    Level
    Quote Originally Posted by CandleCookie View Post
    That is great idea i appreciate you.
    satellite meter| dish-antenna |Broadcast monitors
