Cant connect to License Server, while others can ( Telnet does not work either)
seen25
Newbie level 5
I have a weird problem.
I am trying to connect a Cadence License server that is located in Turkey, but I cannot connect to server.
when I try
telnet xxx.com 5280
GIVES:
telnet: Unable to connect to remote host: Connection timed out
But people in turkey can connect, I first thought it may be some MAC filtering, but it turned out to be its not the case. I dont have firewall or etc, what could be problem?
Check if u can ping the server. if u cant try tracing the route.
I can ping the server, but license server is at port 5280, which is closed.
thanks anyway
If you are using Linux system then
1) disable SELinux
2) Disable firewall (iptables -F)
then try telnet
