programs for beginners in programming (High level language programming)
MahmoudHassan
Full Member level 6
while i was studying programming , i found that it is hard to write a complete code for a program so that you can show it as a complete product
we can collect good small projects for beginners , i think it will be helpful
________________________________________________
First program
Flip my text
or my text is upside down
Everybody write like that !
¡sıɥʇ ǝʞıl ǝʇıɹʍ ʇ,uɐɔ ı ʎɥʍ
it is too simple
see the product in the attached files
how to do this ?
whenever your programmed language (c,c++,c# or java)
you need to strings hat will be treated like arrays
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
string dow = "68ㄥ9 ގㄣᄐᄅ⇂0zxɔʌquɯlʞɾɥƃ ɟpsɐdoınʎʇɹǝʍbZXϽ ΛqNWLʞɾHƃℲpS∀dOInʎ⊥ɹƎMÕ',,˙¿¡&-‾<>)(}{][";
// string of flipped chars
string up = "9876 543210zxcvbnmlkjhg fdsapoiuytrewqZXC VBNMLKJHGFDSAPOIUYTREWQ,'`.?!&-_><(){}[]";
// string of ordinary chars not flpped one
string get = textBox1.Text;
// string that written by the user
int t;
string n="";
for (int i = 0; i < get.Length; i++)
foreach (char x in up) // go to the char in get search for it in ordinary string
if (get==x)
t = up.IndexOf(x);
n = n + dow[t]; // after you find it's index put it in the string n
break;
int j = n.Length - 1;
string lr = ""; // make it left to write
for (int i = 0; i < n.Length; j--,i++)
lr = lr + n[j];
textBox2.Text = lr; display it in textbox2
finally don't forget to put good icons
Mahmoud Hassan
  • FlipMyText.rar
If you have a inverted character set then it is as simple as ABC... means do a string reverse then map all the characters to inverted characters.
Long back IIRC in 1988-89 I wrote a small program in "basica" without using graphic function to enlarge characters in text mode. I did it by reading each individual pixel then replacing them with "*".
But I have never tried such a thing for last several years. I guess it is possible if some how we read the pixels. in the display buffer.
Then we can mirror those pixels and print the inverted string.
