WANTED! Grundig MO-53 or MO-22 oscilloscope schematic
oldmp
Member level 1
grundig mo22
last week, my scope (MO-53) made the following: on the left side of the screen, the beam made a high intesity, big point... so big, that the full screen was green. I think, that the controller circuit, which is responsible for the turnig up of the beam is faulty. Since last weak, unfortunately it appears often. I searched the NET, for the schematic, without a result... :-( But I found a site, with pictures from the MO-22, and it has got the same fault, as mine...
My question is, that have somebody a schematic for this scope? Or, while it appears to be a typical fault, the correct reason?
siemens d 1004
Moved from Professional Hardware and Electronics Design. Please use correct forum.
/pisoiu
oscilloscopio grundig
This scope was also manufactured as a Siemens D 1004.
I have repaired a lot of scopes in the past and will have a search through my old documents to see if I still have a circuit for this.
Could you post a pic of the fault and I may try and give some ideas to repair?
