Could anybody advise me on MOSFET driving circuit ?
ayeong
Full Member level 1
MOSFETS Basic
Based on datasheet, it is true that the higher the VGS for a N-Channel MOSFET will result in a lower RDS(on) ?
And if that's the case, isn't it will be much easier to operate a P-Channel MOSFET than N-Channel since it only require a low on the gate ?
Where do we usually find the minimum voltage to turn on a N-Channel or P-Channel MOSFET ?
For a P-Channel circuit, why do designer usually attached a huge resistor (in KOhm to MOhm range) between the gate and source ?
For the above MOSFETS, I'm referring to the following MOSFET
Vishay - Si1413DH (P-Channel)
https://www.vishay.com/product?docid=71878&query=si1413
Vishay - Si1406DH (N-Channel)
https://www.vishay.com/product?docid=70684&query=si1406
Thanks
Cheers,
Re: MOSFETS Basic
The push/pull driver is very popular using a PNP and NPN transistor with bases tied together as the input and emitters tied together as the output. A low value of resistor around 22-100Ohms is conected from this output to the gate to prevent parasitic oscillations when switching. The 2 collectors are tied to the supply rails according to their proper polarities. Some times a backward diode is connected over the gate resistor to help speed-up the turn off cycle.
There's rarely ever a need to switch above 9V or so on the gate as any voltage above this will only make a very marginal improvement upon the on-resistance, and also remember that you need to discharge the input and that takes time and current that rapidly increases with switching frequency. The total capacitance you have to charge-discharge on the gate will also increase with the Miller capacitance reflected back into the gate which again depends on the voltage swing on the output of your device. This switching off period is very important with inductive loads.
This device operates on a different polarity, low voltage to turn on and high to turn off. The drain connects -ve with respect to the source. P-Chan devices normally have higher on-resistances for the same die size.
There's normally a curve of VGS/V against gate charge QG/nC on the datasheet. The part where the curve starts to be horizontal the device starts turning on properly. On average around 3-4V
This will prevent the device from accidently turning on by keeping the gate discharged with no drive connected.
Re: MOSFETS Basic
No. P-MOSFET only requires a low on the gate, but it requires a high on the source.
Re: MOSFETS Basic
Thanks to E-Design & Hughes.
Btw, does anybody happen to know of any MOSFET that have the lowest ON resistance (RDS ON) for about 10V & less than 3A application (preferably SOT-23 package) ?
Thanks
Cheers,
Re: MOSFETS Basic
a simple inverter (( with appropriate p/n ratio) is a good driver
Re: MOSFETS Basic
Hi All,
Found some good links for MOSFETS :
Fairchild - Introduction to Power MSOFETS & Applications
Fairchild - MOSFETs Basic
International Rectifier - MOSFET
Motorola - Interfacing Power MOSFETs to Logic Devices
Overall, that website is very informative for all EEs
Hope it helps
Cheers,
Re: MOSFETS Basic
All mosfet company have mosffet basic application note.it is basic but also useful.
Re: MOSFETS Basic
8) Hi ayeong,
the reason for putting a high value resistor from gate to source is to avoid false switching of the fet, because the input impedence is very high a small amount of voltage induced on th gate gan turn it on.
generally the mosfet will turn on after its gate voltage threshold is reached.
Zetex is also manufacturing small mosfets.
www.zetex.com
Re: MOSFETS Basic
The reason that gate resistor for PMOS is larger than NMOS is that, for the same RDS(on), normally PMOS will have much larger gate area and Qgd than NMOS one. The large gate resistor can slow down the transient change of the drain voltage and improve the switch on time.
U will find that NMOS is usually used as it is usually much more inexpensive, especially high power MOSFET
Re: MOSFETS Basic
Hi All,
thanks for the reply.
By connecting a resistor between the Gate & Source for a P-Channel to prevent accidental switching, so how do we size that resistor ?
Based on some calculation or simply just a rule of thumb ?
Thanks
Cheers,
Re: MOSFETS Basic
If you have a push-pull driver (say MAX4426 for example), you don't need resistor between gate and source. You only need a right resistor between driver output and MOSFET gate.
