+ Post New Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 45
  1. #1
    Junior Member level 1
    Points: 464, Level: 4
    Join Date
    Dec 2010
    Posts
    16
    Points
    464
    Level
    1000W 12V d.c. to 230V a.c. power schematic diagram
    Can someone help me with the circuit diagram of a 1000W, 50Hz, 12v d.c. to a.c. which is practical.
  2. #2
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Re: 1000W 12V d.c. to 230V a.c. power schematic diagram
    Since you say practical, 1000W at 12v is asking too much. You should be trying with 24V at least. Take a look at this (1250VA, 24v):
    Hope this helps.
    Tahmid.
    ---------- Post added at 15:06 ---------- Previous post was at 15:06 ----------
    This is a complete inverter with all protection schemes and battery charger.
    4 members found this post helpful.
  3. #3
    Advanced Member level 2
    Points: 5,722, Level: 17
    Join Date
    May 2006
    India
    Posts
    644
    Points
    5,722
    Level
    17
    hi Tahmid,
    can u please give what Q1 BC547 is doing ( the transistor from gate to ground )
    1 members found this post helpful.
  4. #4
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    It's used to make sure the MOSFETs remain absolutely off during charging as the internal diodes are used, so that there is no short circuit. In the inverter I posted, I've tried without this transistor and instantly the MOSFETs blew off. When I placed this transistor, everything is fine. The MOSFET driver stage, ie, the diodes and transistor, this scheme is used in most inverters in Bangladesh and India as I have seen.
    Hope this helps.
    Tahmid.
    •   Alt16th December 2010, 15:01
      advertising
  5. #5
    Join Date
    May 2006
    India
    Posts
    644
    Points
    5,722
    Level
    17
    i have seen this circuit , but in my design there is no transistor like this, mosfet driving directly from 3525 found no problem in past 7 years,
    any difference in pwm mode by using this transistor?
  6. #6
    Banned
    Points: 4,222, Level: 15
    Join Date
    Nov 2009
    Nigeria
    Posts
    503
    Points
    4,222
    Level
    15
    The transistor is used as a protection to the mosfet,normaly the oscilator out put is out of phase with the other, failure to change in phase the transistor conduct and pull down the gate to ground to protect the mosfet from getting damage,3525 has no open collector therefore it can use to drive mosfet directly without any buffer,also the circute Tahmid post is a modified sine output and it's working fine.
  7. #7
    Junior Member level 3
    Points: 1,562, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    Chittagong,BANGLADESH
    Posts
    26
    Points
    1,562
    Level
    9
    Tahmid,
    as sala mu alay kum, I see your schematic,its good,if have PCB layout with component placement,please post.thanks.
  8. #8
    Newbie level 6
    Points: 530, Level: 4
    Join Date
    Apr 2010
    africa
    Posts
    12
    Points
    530
    Level
    Tahmid, I appreciate for the circuit, you did it, congrants
    ---------- Post added at 07:01 ---------- Previous post was at 06:59 ----------
    rajudp, can you post your circuit also.
  9. #9
    Points: 2,012, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Tahmid, I luv to try this circuit,but a small part of it I cannot see it very well.
    Please kindly assist.
    Thanks
    •   Alt18th February 2011, 08:08
      advertising
  10. #10
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    I will try to upload it again.
    •   Alt18th February 2011, 13:49
      advertising
  11. #11
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Thanks, you are are nice man...
  12. #12
    Member level 2
    Points: 745, Level: 5
    Join Date
    Jan 2010
    Posts
    43
    Points
    745
    Level
    Thanks Tahmid for the circuit
    Can you please explain what is the function of 4X 1N4148 diodes ZD2,ZD3,ZD4,ZD5 in the base of Q1 BC 547?
  13. #13
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Pls Tahmid, don't to post the circuit....
    Thx
    ---------- Post added at 18:58 ---------- Previous post was at 18:56 ----------
    Pls Tahmid, don't forget to post the circuit....
    Thx
  14. #14
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Please, can any one help on this inverter circuit? any assistance I will appreciate it...
    Thanks
  15. #15
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Tahmid, please am still expecting that inverter circuit as promised....
    Thanks
  16. #16
    Member level 2
    Join Date
    Jan 2010
    Posts
    43
    Points
    745
    Level
    hey Tahmid wake up !!
    9 days gone and we are all waiting for you to upload that inverter circuit in full
  17. #17
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    I am very busy with my exams. Haven't signed in for the last few days. Will try to post it tomorrow.
  18. #18
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    I which you best in your Exams,my Tahmid.
    ---------- Post added at 22:33 ---------- Previous post was at 22:27 ----------
    Please, don't forget to post it again....
  19. #19
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Here it is:
    This could be helpful to many:
    Thanks.
    Hope this helps.
    Tahmid.
    ---------- Post added at 22:54 ---------- Previous post was at 22:51 ----------
    Quote Originally Posted by khossanr View Post
    Tahmid,
    Sorry, I don't have the PCB layout.
    2 members found this post helpful.
  20. #20
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    7
    Points
    2,012
    Level
    10
    Thanks Tahmid, I really appreciate it.
    and I will make sure that i try it....
    •   Alt13th March 2011, 21:43
      advertising
