+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 3
    Points: 681, Level: 5
    Join Date
    Jun 2010
    India-Chennai
    Posts
    26
    Points
    681
    Level
    Problem with using PNP transistor BC557 and a LED
    I intend to use BC557 (PNP) transistor in indicator circuit, +at pin 1 (E), connect a + pin of LED at pin3(C), and the -pin of LED to Ground, the LED is not glowing (6V input), when positive volt is given through pin2 (B) the LED is glowing, since the transistor is PNP type if the base is biased the LED should glow and the Base is positive the LED should be OFF, the circuit is not working pls help
    •   Alt14th December 2010, 09:55
      advertising
  2. #2
    Advanced Member level 3
    Points: 5,999, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Re: PNP Transistor BC557
    Please put a resistor around 330 to 1k to the LED, if not, you might burn your LED
    ---------- Post added at 10:44 ---------- Previous post was at 10:37 ----------
  3. #3
    Newbie level 2
    Points: 1,193, Level: 7
    Join Date
    Apr 2006
    England, UK
    Posts
    Points
    1,193
    Level
    7
    bushygs
    I suspect you have destroyed the BC557. You need some current limiting, i.e. a resistor, in series with your LED to protect both the transistor and the LED.
    A red LED will have a forward voltage of around 2V when forward biased, and a blue or white one will have around a 4V drop. Add in the CE voltage drop of the transistor (approx. 0.2V say) and the rest of the applied 6V supply voltage must be dropped across a resistor in series with the LED.
    Assume a current of 15mA through a red LED, then 6V - 2V - 0.2V = 3.8V, which divided by 15mA = 253ohms. Choose a 220ohm resistor and the current will be a little higher at approx 17.3mA. Your LED and your transistor are now protected, although you really ought to limit the base current with some resistance also. If you are pulling the base down to ground then you need maybe 47k in series with the base to protect the BE junction of the transistor. Hope this helps.
  4. #4
    Join Date
    Jun 2010
    India-Chennai
    Posts
    26
    Points
    681
    Level
    Re: Problem with using PNP transistor BC557 and a LED
    Sorry i had used a 220ohms at the ground connection of LED. i am uploading the image file to show the schematic.
    When the Voltage is below 10V the Zener would not conduct and the BC557 PNP transistor should conduct and the LED should be in ON state, if the voltage is above 10V the Zener would conduct and would reverse bias the BC557 and stop it from conducting and the LED should be in OFF state.
    Please advice where I am wrong
    •   Alt14th December 2010, 14:28
      advertising
  5. #5
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    reverse the zener ..
    :wink:
  6. #6
    Newbie level 2
    Join Date
    Apr 2006
    England, UK
    Posts
    Points
    1,193
    Level
    7
    Absolutely, IanP.
    bushygs - 'conventional' current flow is out of the base in a PNP transistor.
    •   Alt14th December 2010, 15:57
      advertising
  7. #7
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Yup, your zener is reversed :)
  8. #8
    Join Date
    Jun 2010
    India-Chennai
    Posts
    26
    Points
    681
    Level
    I need the LED to glow when the voltage drops below 11 volt (ie.zener 10 + base current of 1 volt), by reversing the zener the LED glows at 12+ volt and is off, it it is below 11 volt.
  9. #9
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    if you need that condition, use NPN or you have to use BC557?
  10. #10
    Join Date
    Jun 2010
    India-Chennai
    Posts
    26
    Points
    681
    Level
    I have used BC557 (PNP) only in the circuit, so as to give the opposite function of BC547 (NPN).
