+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 2
    Points: 2,460, Level: 11
    Join Date
    Jul 2003
    Sofia, Bulgaria
    Posts
    44
    Points
    2,460
    Level
    11
    switch orcad
    Hi to all!
    I want ot model the behaviour of a transistor as an electronic swich. Hence I don't know the type of the transistor,yet so I want ot model it's behaviour as a swich by some element which has two states ON and OFF!!!
    Is there such element in PSPice libraries or not?
    10x in advance
    •   Alt10th June 2004, 19:11
      advertising
  2. #2
    Advanced Member level 2
    Points: 5,237, Level: 17
    papyaki's Avatar
    Join Date
    Apr 2002
    France
    Posts
    539
    Points
    5,237
    Level
    17
    orcad switch
    You can use voltage controlled switch (Sbreak) or current controlled switch (Wbreak). This components are also available in the lite version of pspice, pspice student.
    1 members found this post helpful.
  3. #3
    Member level 2
    Join Date
    Jul 2003
    Sofia, Bulgaria
    Posts
    44
    Points
    2,460
    Level
    11
    pspice switch model
    10x for the answer papyaki! :)
    Can you or someone else tell me how to control this swich?
    I read the PSpice user giude and saw about this swich, but did'n figure out how to controll it. The control voltages are set to Voff=0.0 Von=1.0.
    The swich is connected with VPULSE source whis values are: V1=0V, V2=5V. Unfortunateluy the swich didn't toggle :(
    Here is the configuration
    Is this configuration correct?
    10x for the answers
    •   Alt11th June 2004, 22:34
      advertising
  4. #4
    papyaki's Avatar
    Join Date
    Apr 2002
    France
    Posts
    539
    Points
    5,237
    Level
    17
    switch in orcad
    I have simulated the schematic here after with your Vpulse parameters.
    It gives the probe following curves with Vin = Vpulse and Vout = switch output.
    Did you use a power supply and a resistor in serie with the switch output ?
    The switch is a resistor with two possible values : Ron = 1 ohm and Roff = 1E9 ohms
  5. #5
    Member level 2
    Join Date
    Jul 2003
    Sofia, Bulgaria
    Posts
    44
    Points
    2,460
    Level
    11
    sbreak orcad
    This configuration works just fine!
    10x again papyaki!
    This swich is very suitable to model the behaviour of a MOSFET transistor!
    I wanted to see if the swich is working and to concentrate on the circuit.
    Now I am sure it is!
    •   Alt12th June 2004, 20:49
      advertising
  6. #6
    Newbie level 1
    Points: 794, Level: 6
    Join Date
    Jul 2008
    Posts
    Points
    794
    Level
    orcad vpulse
    Still usefull 4us students, thanks for the original solver.
  7. #7
    Advanced Member level 3
    Points: 6,635, Level: 19
    Sadegh.j's Avatar
    Join Date
    Nov 2006
    Posts
    754
    Points
    6,635
    Level
    19
    switch library orcad
    In orcad Pspice, there are websites that have modeled the components and from which you can freely download what ever you want. Search the web
