+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Newbie level 1
    Points: 370, Level: 4
    Join Date
    Dec 2010
    Posts
    Points
    370
    Level
    Advantages of three phase systems over single phase
    Hi, Can anybody help me??
    Describe the advantages of three phase systems as opposed to single phase and list the different methods of connection. Include the relationship between line and phase voltage and current for each type??
    Any help would be greatly appreciated, regards, Tom
    •   Alt8th December 2010, 15:33
      advertising
  2. #2
    Advanced Member level 2
    Points: 5,766, Level: 18
    Achievements:
    7 years registered
    Prototyp_V1.0's Avatar
    Join Date
    Apr 2007
    Norway
    Posts
    643
    Points
    5,766
    Level
    18
    Re: Three phase systems?
    School work, yes?
    One advantage is that the physical strenght of a three phase cable is greater because it have three or four wires instead of just two.
  3. #3
    Newbie level 5
    Points: 301, Level: 3
    Join Date
    Aug 2011
    Triprayar,Kerala,India
    Posts
    10
    Points
    301
    Level
    Re: Advantages of three phase systems over single phase
    Three phase has higher voltage and can drive high volume of mass if it used for a pulling or rotating job. more power more work can be completed.
  4. #4
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Norway
    Posts
    643
    Points
    5,766
    Level
    18
    Quote Originally Posted by koppan View Post
    Three phase has higher voltage . . .
    This isn't always the case
    Beside, he's semester is finished and the question is likely solved long time ago.
    1 members found this post helpful.
  5. #5
    Advanced Member level 5
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    The big advantage with 3 phase mains is that any electric motor connected to it is more efficient, has smother running and uses less parts so is more reliable. There is also a slight advantage in using 3 phase transformers over single phase ones. There is a great advantage in AC to DC power supplies as smaller capacitors can be used. For other applications such as heating and lighting it has no advantage.
    Frank
    Last edited by chuckey; 31st August 2011 at 08:00. Reason: Added rectification sentence.
    •   Alt31st August 2011, 07:58
      advertising
  6. #6
    Points: 253, Level: 3
    Join Date
    Aug 2011
    Singapore
    Posts
    7
    Points
    253
    Level
    The 3 phase system has an advantage for the single phase system for sure, the 3 phase system has more power than the single phase system, such that p=3vicos(theta).
    NO SIGNATURE LINKS ALLOWED
  7. #7
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    Three phase motors are inherently self-starting because of the rotating filed produced by the 3 phase current.
    If the load is balanced, there is no neutral current flow (in the case of a Y (Wye, Star) connection.
    In a delta connection, you can lose (open) one phase, and you still have three phase power available, although thecurrent flow from the source will be greater.
  8. #8
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Norway
    Posts
    643
    Points
    5,766
    Level
    18
    Quote Originally Posted by Kral View Post
    I disagree that. Please explain.
  9. #9
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    The delta connection in which one phase (Secondary Winding) is missing is called the "open delta" connection. The following article explains it better than I can:
    E.T.E. 3 Phase Transformer Info
    This connection is useful in situations where the load is expected to grow over time. You can start initially with an open delta, and as the load requirements increase, you can add the third transformer without disturbing the system.
    •   Alt6th September 2011, 15:51
      advertising
  10. #10
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    I guess, the open delta configuration is a typical US special. I noticed, that in the US, it's still common to mount three single phase transformers on a power pole instead of a more economic three-phase transformer. In this case, you can think about omitting one for reduced load. Unfortunately, you get asymmetric current capabilities of each phase.
  11. #11
    Achievements:
    7 years registered
    Join Date
    Apr 2007
    Norway
    Posts
    643
    Points
    5,766
    Level
    18
    I still disagreed with your statement that I quoted.
    However, you could just add "by using two single phase transformers" to make the statement true.
    An open delta configuration must contain two identical single phase transformers.
