+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 3
    Points: 1,363, Level: 8
    Join Date
    Nov 2010
    Posts
    62
    Points
    1,363
    Level
    8
    how to set ground plane dimension in ie3d
    hello
    can anybody tell me how can i set dimension for ground plane in ie3d. i have to design a probe feed microstrip antenna and i have to work on some papers in which they have given me the dimension for ground plane but i dont know how to set the dimension for ground plane in ie3d. please please somebody tell me step by step procedure.
    i will be very thankfull to you.
    regards
    sameer
    •   Alt4th December 2010, 05:11
      advertising
  2. #2
    Points: 436, Level: 4
    Join Date
    Aug 2010
    india
    Posts
    7
    Points
    436
    Level
    Re: how to set ground plane dimension in ie3d
    jst select layer corresponding to ground plane and then in that layer draw rectangle with required dimensions....dat shld do
  3. #3
    Member level 3
    Join Date
    Nov 2010
    Posts
    62
    Points
    1,363
    Level
    8
    Quote Originally Posted by cant-bury View Post
    not able to get you
    •   Alt4th December 2010, 18:28
      advertising
  4. #4
    Join Date
    Aug 2010
    india
    Posts
    7
    Points
    436
    Level
    you must be having different substrate layers...select the bottom layer after you finish your structure and connections.....draw a rectangle in the bottom layer with desired dimensions such that it contains the struct....then give the dimensions......
  5. #5
    Member level 3
    Join Date
    Nov 2010
    Posts
    62
    Points
    1,363
    Level
    8
    i tell you how i do to select the ground plane
    step 1st i select the new file then i give the value of relative permittivity, thickness, and loss tangent in (add substrate layer 1 by thickness) then "ok"
    secone step - then i click to "finite dielectric types" after that "convert from infinite substrate" then another small window appears in which i have to enter the value of "x" and y" cordinates then " ok"
    is this the procedure to select the ground plane or not
    regards sameer
  6. #6
    Join Date
    Aug 2010
    india
    Posts
    7
    Points
    436
    Level
    i dont think dats d process....as far as i know...in IE3D finite ground plane is only possible by setting real part of conductivity of 0 layer to 0 and den d process i mentioned before....
    regards
    •   Alt6th December 2010, 13:19
      advertising
  7. #7
    Member level 3
    Join Date
    Nov 2010
    Posts
    62
    Points
    1,363
    Level
    8
    regards
    hello
    can you do me a favour please,
    i m telling you the parameters of my paper, could you please make the structure in ur ie3d and then can you please send me the ".geo" file
    (no need to simulate) because i think i m not getting the option for entering the dimesion of ground plane bcoz i m using pirated ie3d.
    i have followed your step but...
    by seeing your structure i can try to understand
    these are my parameters
    all dimensions in mm
    Er=2.22
    tangent loss=0.0009
    h=6.985
    GROUND PLANE DIMENSION = 61.2 x 61.2
    W=49.27
    L=32.85
    radiius of probe = 0.635
    probe feed
    x= 10.95
    y=16.42
    if u can send me the structure for these parameters, i will be very thankful to you
    regards
    sameer
