+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 3
    Points: 382, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    382
    Level
    How to use a flip flop in 4 LED random flasher project
    i am just a beginer wid the circuit,working on a small project.its a random flasher in which only 1 LED is ON at a time. i want to use a clock circuit using D flip flop.suppose I need to use 4 LEDs,m not gettin how to use flip flop?
    •   Alt28th November 2010, 09:14
      advertising
  2. #2
    Junior Member level 2
    Points: 1,935, Level: 10
    Join Date
    Nov 2010
    Posts
    21
    Points
    1,935
    Level
    10
    Re: How to use a flip flop in 4 LED random flasher project
    u can made also by using 555 timer ic and decade counter
  3. #3
    Advanced Member level 1
    Points: 4,023, Level: 14
    Achievements:
    7 years registered
    lockman_akim's Avatar
    Join Date
    Jul 2010
    Malaysia
    Posts
    467
    Points
    4,023
    Level
    14
    u also can use CMOS counter IC..try search for CMOS 4000 series..it easy..dont afraid with the name..
    it just 1 or 0
    lockman_akim
    •   Alt28th November 2010, 17:14
      advertising
  4. #4
    Advanced Member level 3
    Points: 4,815, Level: 16
    Achievements:
    7 years registered
    KJ6EAD's Avatar
    Join Date
    Oct 2010
    Earth
    Posts
    709
    Points
    4,815
    Level
    16
    Maybe something like the ring counter shown in this: 4015 dual 4-stage shift register. You run the ring counter at a high enough clock speed to make it seem random when it's stopped by a button push. If you need to conitinuously display random LEDs, try a variation of the pseudo-random method in the same link.
  5. #5
    Newbie level 3
    Join Date
    Nov 2010
    Posts
    Points
    382
    Level
    Quote Originally Posted by sunny1986 View Post
    thnx ,its help ful :)
    •   Alt29th November 2010, 17:50
      advertising
  6. #6
    Full Member level 1
    Points: 1,744, Level: 9
    djsfantasi's Avatar
    Join Date
    Mar 2010
    Boston MA
    Posts
    107
    Points
    1,744
    Level
    9
    Actually, a really cheap, poorly made, pushbutton connected directly to the clock input of a decade counter can also produce a random count. No need for a 555 timer or other clock circuitry. One case where switch bounce is a good thing! Then a BCD to decimal decoder can be used to drive only one LED at a time. This would work for up to 10 LEDs if all bits were used; if the upper two bits to the decoder where pulled low, then one of four - as per the original post - would light. I've used this technique in the past...
  7. #7
    Achievements:
    7 years registered
    KJ6EAD's Avatar
    Join Date
    Oct 2010
    Earth
    Posts
    709
    Points
    4,815
    Level
    16
    The OP has clearly stated an intent to use D-type flip flops.
