BCD to HEX IC, thmbwheel & 7segment interfacing
Bhavik Shah
Newbie level 6
bcd hex ic
Q1)which IC can be used as a BCD to HEX converter?
Q2)circuit diagram or methodology for interfacing 4 thumwheel switches &
4 digit 7 segment display?
bcd hex c
Q2/Thumbwheel switch.
Common pin connected to ground. Each other pin connected to an input port of a mcu or to an input of a buffer with a pull up resistor.
Q2/7 segment
see this schematic as an example :
h**p://chaokhun.kmitl.ac.th/~kswichit/2051/7-seg/7-seg.htm
* = t
