Simulation error....in pspice orcad full version 9.2..........
chanchal1431
Newbie level 2
cochin
**** 11/20/10 13:22:47 ************** PSpice Lite (Mar 2000) *****************
** Profile: "SCHEMATIC1-BFSK wave" [ C:\DOWNLOADS\chancircuit\bfsk waveform generator-schematic1-bfsk wave.sim ]
**** CIRCUIT DESCRIPTION
** Creating circuit file "bfsk waveform generator-schematic1-bfsk wave.sim.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Program Files\OrcadLite\PSpice\PSpice.ini file:
.lib "eval.lib"
.lib "breakout.lib"
.lib "nom.lib"
*Analysis directives:
.TRAN 0 10ms 0 0.1ms
.PROBE V(*) I(*) W(*) D(*) NOISE(*)
.INC ".\bfsk waveform generator-SCHEMATIC1.net"
**** INCLUDING "bfsk waveform generator-SCHEMATIC1.net" ****
* source BFSK WAVEFORM GENERATOR
X_X1 0 N00424 N00509 N00275 N00659 N00424 N00354 N00275 555D PARAMS:
+ MAXFREQ=3E6
V_V1 N00275 0 5Vdc
C_C1 0 N00424 0.1uF
C_C2 0 N00659 0.01uF
R_R1 N00354 N00275 4.7k
R_R2 N00424 N00354 10k
V_V2 N01195 0
+PULSE 0 5 0 0 0 0.005msec 0.01msec
R_R3 0 N00509 1k
R_R4 N00354 N01796 1k
Q_Q2 N00275 N01829 N01796 QbreakN
R_R5 N01195 N01829 1k
**** RESUMING "bfsk waveform generator-schematic1-bfsk wave.sim.cir" ****
.END
ERROR -- Subcircuit 555D used by X_X1 is undefined
please help me ..................................thanks in advanceView attachment bfsk.rar
I think you are missing the 555 spice model, if i remember correctly there is a library inside the capture folder which is schematic only (every .olb file is a schematic library ) and there is a pspice folder (inside capture folder) which has the .olb schematic library and a .lib simulation model with the same name.
You should use the pspice library for simulation.
Alex
---------- Post added at 11:03 ---------- Previous post was at 10:50 ----------
I reviewed your .obj file and for 555 it says
(555D
      (FullPartName "555D.Normal")
      (LibraryName "C:\PROGRAM FILES\ORCADLITE\CAPTURE\LIBRARY\PSPICE\EVAL.OLB")
      (DeviceIndex "0")))
check in folder C:\PROGRAM FILES\ORCADLITE\CAPTURE\LIBRARY\PSPICE there should be a eval.lib file with the subcircuit model for 555
You are also using a lite version from what i can see from the installation path "C:\PROGRAM FILES\ORCADLITE" , i don't know if there are only basic library's included or if there is some other limitation
Alex
