+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 5
    Points: 2,570, Level: 11
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    india
    Posts
    264
    Points
    2,570
    Level
    11
    How to convert RJ11 to audio jack for stereo headphone?
    Dear all,
    i want to use stereo headphones in my telephone where RJ11 female is connected.is it possible to convert RJ11 jack to stereo jack for my headphone?
    hope you people must have done this.please suggest me how to do it.
    Thanks i advance.
  2. #2
    Full Member level 3
    Points: 2,147, Level: 10
    sanjubluerock3's Avatar
    Join Date
    Sep 2008
    Bengaluru, India
    Posts
    174
    Points
    2,147
    Level
    10
    Re: How to convert RJ11 to audio jack for stereo headphone?
    that's simple u will get a converter from rj 11 to 3.5mm audio jack.. i am using the one which i got with cenix voice recorder
    •   Alt12th November 2010, 12:17
      advertising
  3. #3
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    india
    Posts
    264
    Points
    2,570
    Level
    11
    can't we make ourself instead of buying from outside?
    •   Alt12th November 2010, 13:40
      advertising
  4. #4
    Full Member level 3
    Join Date
    Sep 2008
    Bengaluru, India
    Posts
    174
    Points
    2,147
    Level
    10
    its easily available within 50 rs ...u can make one... get 3.5mm connector stereo or mono and u can get a rj 11 cable reay made crimped on both the ends cut one side and connect the 3.5 mm ...that's it simple...
    •   Alt12th November 2010, 18:54
      advertising
  5. #5
    Newbie level 2
    Points: 384, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    384
    Level
    I searched all over hyderabad but i could not find it. Friend kindly can you tell me from where can i buy Rj 11 to 3.5mm converter ?????
  6. #6
    Full Member level 3
    Join Date
    Sep 2008
    Bengaluru, India
    Posts
    174
    Points
    2,147
    Level
    10
    just get the rj11 cable and 3.5mm connectors.... from any local store.. cut one end of rj 11 cable and solder the 3.5m connector that's it...but here in Bangalore (rj11-3.5mm) is available..
    1 members found this post helpful.
  7. #7
    Newbie level 2
    Join Date
    Nov 2010
    Posts
    Points
    384
    Level
    i bought both. I have cut the Rj 11 cable also. But Rj 11 cable has 4 wires whereas i need to connect them to two 3.5mm connectors and i dont know which wires to connect to what.....????? kindly help......:):
    •   Alt16th November 2010, 07:54
      advertising
  8. #8
    Full Member level 3
    Join Date
    Sep 2008
    Bengaluru, India
    Posts
    174
    Points
    2,147
    Level
    10
  9. #9
    Advanced Member level 3
    Points: 6,212, Level: 18
    Join Date
    Apr 2006
    Hyderabad, India.
    Posts
    789
    Points
    6,212
    Level
    18
    check with MX electronics in koti, HYD market
