50 ohm transmittion line calculation?
modelstudent
Newbie level 6
50 ohm feed line calculation?
hello, i am working on a multiband antenna with subpatch, the main part of the anteena is finished but i dont know how to calculate the feed line dimension, and i just try the dimension one by one now, are there any efficient way that i can get the dimension?
i am using ADS to simulate my antenna.
many thanks!! :p
In ADS Schematic, go to Tools > Linecalc
This is a tool that calculates the required line width.
the linecalc only calculate the width of feed line at one operating frequency,doesnt it?
however, my antenna is multiband, which frequency should i input ?will it work?
many thanks~!
thats mean i can choose either one to input and get the results?
after i get the width, then i should adjust the length of the feed line until i get a good S11 results?
Ooops ... you said that you want a 50 ohm line, so that the line is matched to the 50 ohm source -> no impedance transformation -> length does not matter
does the antenna design related to the impedance of feed line?
Reactions: saweng
    saweng
