+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 4
    Points: 924, Level: 6
    Join Date
    Oct 2010
    NEPAL
    Posts
    73
    Points
    924
    Level
    What's the function of SG3524 IC in an inverter circuit?
    hi every one..
    i found this IC...SG3524... on my inverter..which i bought from the market..
    i have read the datasheet but could not find the reason behind this IC to be used in inverter.circuit ...my inverter is 50watt...
    anyone please can you explain how this IC works..
    every help will be appreciated
  2. #2
    Super Moderator
    Points: 50,308, Level: 54
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,873
    Points
    50,308
    Level
    54
    Re: SMPS control circuit
    I'd think the TI dataSheet explains it rather well, incl. appropriate application info.
    2 members found this post helpful.
    •   Alt1st November 2010, 19:12
      advertising
  3. #3
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Well, this is a PWM chip. For understanding PWM:
    So You Want to Use PWM, Eh? | Non-Lexical Vocables ---------> I recommend this
    Pulse Width Modulation
    Introduction to Pulse Width Modulation (PWM) | Netrino
    Okay then, first get your head straight with PWM and how it works and then go through the datasheet:
    focus.ti.com/lit/ds/symlink/sg3524.pdf
    If then you still don't understand, you'll find many here to help you.
    Take this as reference:
    Hope this helps.
    Tahmid.
    •   Alt1st November 2010, 19:23
      advertising
  4. #4
    Member level 2
    Points: 1,174, Level: 7
    Join Date
    Feb 2012
    Posts
    46
    Points
    1,174
    Level
    7
    Mr Tahmid,i want get 100 khz frekuensi using sg 3524,so we using the formula,but when i make it on pcb and i test and measure with osciloscope,i dont get the frekuensi that i expected
    please help me...
    •   Alt4th February 2012, 04:20
      advertising
  5. #5
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Re: What's the function of SG3524 IC in an inverter circuit?
  6. #6
    Full Member level 6
    Points: 2,120, Level: 10
    Join Date
    Aug 2010
    delhi
    Posts
    323
    Points
    2,120
    Level
    10
    The 3524 has unity gain bandwidth 3MHz and the transition times ON+OFF are 0.3usecs .As such you cannot expect to go beyond 33KHZ as you shall need a min gain of 100 for your drives.
    The supply is 12VDC max. and the pushpull drives at transformer give saturation drops of approx.1VDC for the swing.As such ferrite winding ratio Pri::sec is 1:10 for getting 220VAC
    However , the 3stage Darlington drive pushpull stages can be bettered by using Low Rdon MOSFET like STW80N06 which is 60V/80Amp /Rdson =0.01 ohm.
  7. #7
    Member level 1
    Points: 665, Level: 5
    Join Date
    Mar 2012
    9ja
    Posts
    38
    Points
    665
    Level
    Quote Originally Posted by Tahmid View Post
    Hope this helps.
    Tahmid.
    can u help me out with d pbc layer of dis schematic
    ---------- Post added at 17:16 ---------- Previous post was at 17:14 ----------
    Hope this helps.
    Tahmid.
  8. #8
    Newbie level 1
    Points: 81, Level: 1
    Join Date
    Jan 2013
    Posts
    Points
    81
    Level
    mr tahmid i have built this circuit of pwm invertor which you have posted i have problem that it is not oscillatin i only get voltage at only one output some time i get on pin14 and pin 11 has no voltage and if i turn off i get voltage at pin 11 and no signal at pin 14 please help what to do
  9. #9
    Points: 41, Level: 1
    Join Date
    Apr 2013
    Posts
    Points
    41
    Level
    can we obtain variable frequencies using SG3254??
  10. #10
    Newbie level 5
    Points: 98, Level: 1
    Join Date
    Aug 2013
    Posts
    9
    Points
    98
    Level
    good morning every one,please,mr tahmid i am a child in sg3524,i followed ur blogs on this but not been able to find any,d only one i saw with detailed explanation was sg3525,pls am in need of the functions of all these pins,if u have worked with that before can u help me post the blog address so i can read through,i enjoy that 4 sg3525 (self explanatory)
    •   Alt7th September 2013, 05:53
      advertising
  11. #11
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    Oct 2013
    Posts
    Points
    13
    Level
    hey guys need help..i just want to ask, is it possible that using IC sg3524 can have an output of 10 hz frequency and how can i achieve it.
  12. #12
    Member level 2
    Points: 982, Level: 7
    Join Date
    Oct 2011
    Posts
    42
    Points
    982
    Level
    7
    Mr tamid could we design a sine wave inverter circuit using the sg3524 as part of the circuit. Thank u
