+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Advanced Member level 2
    Points: 3,537, Level: 13
    incomplete_jerin's Avatar
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Hex value To BCD conversion.
    Can anyone give me an idea of the logic behind converting a 8 bit value to BCD value with an example?
    I searched in net but couldn't find a nice one.
    Thanx in advance.
    Jerin.
  2. #2
    Advanced Member level 3
    Points: 4,815, Level: 16
    Achievements:
    7 years registered
    KJ6EAD's Avatar
    Join Date
    Oct 2010
    Earth
    Posts
    709
    Points
    4,815
    Level
    16
    Re: Hex value To BCD conversion.
    The Wikipedia article on this is pretty good. Binary-coded decimal - Wikipedia, the free encyclopedia There ia a previous thread here on the subject: http://www.edaboard.com/thread31757.html.
  3. #3
    Full Member level 1
    Points: 2,567, Level: 11
    Join Date
    Apr 2005
    Posts
    97
    Points
    2,567
    Level
    11
    •   Alt22nd October 2010, 13:44
      advertising
  4. #4
    Super Moderator
    Points: 8,197, Level: 21
    Join Date
    Jun 2009
    Japan
    Posts
    1,056
    Points
    8,197
    Level
    21
    Hello!
    What do you want to know exactly?
    The logic behind this is simply to convert. Here is an example:
    In decimal, you writ for instance 77, which converts to 0x4D in hexa, but
    to 0x77 in BXD.
    So you want to convert a decmal to BCD?
    uint8 val;          // The value you want to convert
    uint16 bcdval;   // The converted value
    uint8 d0, d1, d2; // the 3 decimal figures used to write a 0 ~ 255
    d2 = val / 100;
    val -= 100 * d2;
    d1 = val  / 10;
    d0 = val % 10;
    bcdval = d2 << 8 + d1 << 4 + d0;
    That's it.
    Dora
  5. #5
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    I want to convert a hex value(8 bit) to BCD.Actually we do add 6 to the hex values that has lower nibbles ranging from 'A' to 'F' only or we add 6 to all the hex values greater than 0x09?
    Thanking you & Regards,
    Jerin.
  6. #6
    Super Moderator
    Join Date
    Jun 2009
    Japan
    Posts
    1,056
    Points
    8,197
    Level
    21
    Hello!
    Adding 6 will indeed work for any number between 10 and 15. (A and F).
    Now I would be curious about your algorithm for greater numbers.
    For example 0x20 should result in 0x32 in BCD. According to what you
    say, since the low nibble is 0, then you don't add anything. And since
    the higher nibble is 2, you don't add anything either. Could you explain
    me how you will find 0x32?
    By the way is there any problem in the algorithm I suggested?
    At least it is simple.
    Dora.
    Quote Originally Posted by incomplete_jerin View Post
    Jerin.
  7. #7
    Super Moderator
    Points: 69,545, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,367
    Points
    69,545
    Level
    64
    Be careful. Adding or subtracting 6 will adjust the high or low half of a hex number to it's binary equivalent but it will not take care of overflow from one digit to the next. Please remember that any hex number above 0x64 will convert to three BCD digits not two so the result has to be saved in two bytes.
    I suggest you look at PIC Microcontoller Radix Math Methods for some proven code.
    Brian.
    •   Alt23rd October 2010, 09:23
      advertising
  8. #8
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Actually i posted this doubt in order to make a 0-999 BCD counter.Now i'm tryin to make it a 0-99 BCD counter first so that i can display the number in two 7 segment BCD display.......
    There i fin difficulty in converting the numbers with lower nibble ranging from 'A' to 'F'...... Can anyone help me in this situation?
    Thanking you & regards,
    Jerin.
    •   Alt23rd October 2010, 09:56
      advertising
  9. #9
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,367
    Points
    69,545
    Level
    64
    Look at it this way:
    0 - 9 Just keep as they are
    A - F Subtract 10 and carry one to the next higher digit.
    Brian.
  10. #10
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Dear brian,
    Can you explain with an example please? Yet i couldn't figure it out...
    For eg: how will you convert the numbers with lower nibble b/w 'A'to 'F' & numbers other than that but greater than 0x0F to BCD?
    I'm just pondering over it.......... ?:
    Jerin.
  11. #11
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,367
    Points
    69,545
    Level
    64
    The link I gave shows how to do it in assembly language and the code can be wrapped in 'C' asm segment.
    In 'C', do it like this, entering with the value in 'HEXVal':
    unsigned char MSD, LSD; // Most and Least significant Digits
    LSD = HEXVal & 0x0F; // isolate the lower 4 bits
    if(LSD > 10) // adjust if A - F
    LSD -= 10;
    MSD++;
    MSD += ((HEXVal & 0xF0) >> 4);
    That's it for two digits but be careful if the value causes an overflow, the full range of 0x00 to 0xFF that fits in a single byte will decode to THREE BCD digits 000 to 255 so values decoding to D'99' or 0x63 will need that extra BCD digit.
    Brian.
  12. #12
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Dear brian,
    What is the logic behind shifting the MSB to the right by 4?Also the initial values of the 2 char variables must be 0 rite?
    LSD -= 10;
    MSD++;
    Here each time when MSD increments do we have to initialize MSD to 0 after it has incremented & added?
    Regards,
    Jerin.
    ---------- Post added at 06:29 ---------- Previous post was at 04:58 ----------
    Got it Brian.........!!!!!!!!!!!!
    Thank you very much for you ideas........!!!!!!!!!!
    The code is as follows:
    B]Counter from 0-99[/B]
    char i=0,key = 0,a = 0,keyval = 0,
    val[] = {0x10,0x20,0x30,0x40,0x50,0x60,0x70,0x80,0x90};
    short int temp = 0,keytemp = 0;
    void main()
    ADCON1 = 0x06;
    TRISE = 0x01;
    TRISD = 0x00;
    PORTD = 0x00;
    loop:
    if(PORTE.f0 == 0)
    Delay_ms(150);
    if(PORTE.f0 == 0)
    do
    Delay_us(100);
    }while(PORTE.f0 == 0);
    a += 1;
    if(a > 0x99)
    temp = 0;
    i = 0;
    a = 0;
    goto end;
    if(a == val[i])
    a += 6;
    i++;
    keyval = a;
    keyval = keyval/16; //MSB
    keytemp = a%16; //LSB
    if(keytemp > 0x09)
    keytemp -= 10;
    keyval++;
    keyval = keyval<<4;
    temp = keyval + keytemp;
    end:
    key = temp;
    PORTD = key;
    goto loop;
    It is working BEAUTIFULLY.............!!!!!!!!!!!!!
    Thanks to all for their reply................
    Regards,
    Jerin.
  13. #13
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,367
    Points
    69,545
    Level
    64
    Ugh! you use a 'goto' in C code - but I'll forgive you!
    Incidentally, >>4 is the same as dividing by 16 but the compiler will normally make it from shift instructions instead of using division routines so in most cases it makes smaller and quicker code.
    Brian.
  14. #14
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Is there any other function for goto in C?
    Regards,
    Jerin.
    •   Alt25th October 2010, 10:17
      advertising
  15. #15
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,367
    Points
    69,545
    Level
    64
    Best practice is to structure you program so there are no 'jumps' at all except for calls to functions.
    The trouble with 'goto' is it is very easy to end up in the wrong place, especially if you modify code between the goto instruction and the label it points to. Also be careful if you jump into or out of a function, although it is legal in 'C' you can easily crash your program if you unbalance the processor stack.
    In your program, consider using a 'while' loop to make it repeat instead of 'goto'ing back to the start of the program and consider using the 'break' function to leave when the value reaches 0x99.
    I'm not telling you you are wrong, just suggesting a safer way to write your program.
    Brian.
  16. #16
    Super Moderator
    Join Date
    Jun 2009
    Japan
    Posts
    1,056
    Points
    8,197
    Level
    21
    Hello!
    It is ALWAYS possible to write code without goto. I have never used a single
    goto in many years of programming. The problem of the goto statement is
    that it allows you to jump from anywhere to anywhere else.
    Let's take a look at your code:
    You have a loop label and a goto loop at the end of the program. Why not
    replacing this by a
    while(1) {
        // Insert your loop code here.
    As for the second goto:
    You test if a is greater than 0x99, in which case you reset everything
    and then jump to the label.
    Why not doing:
    			if(a > 0x99) {
    				temp = 0;
    				i = 0;
    				a = 0;
    			else {  // This area is not entered if a > 0x99
    				if(a == val[i])	{
    					a += 6;
    					i++;
    				keyval = a;
    				if(keytemp > 0x09) {
    					keytemp -= 10;
    					keyval++;
    				keyval = keyval<<4;
    			key = temp;
    			PORTD = key;
    As you can see, in case you have a > 0x99, you initialize everything
    and then you skip all the code which is in the else part which is equivalent
    to what you did.
    Dora.
    Regards,
    Jerin.
  17. #17
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Ya. Thanx to both Dora & Brian too.....
    Now i'm on my way to make a 0-999 BCD counter. After i have completed that i will post it here in the forum.
    Jerin.
  18. #18
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Here is the code for 0-999 BCD counter:
    char i = 0,j = 0,k = 0;
    int a = 0,key = 0;
    void main()
    ADCON1 = 0x06;
    TRISE = 0x01;
    TRISD = 0x00;
    TRISC = 0x00;
    PORTC = 0;
    PORTD = 0x00;
    while(1)
    if(PORTE.f0 == 0) //Polling for pin0 of PORTE(Button on pin0 of PORTE)
    Delay_ms(150);
    if(PORTE.f0 == 0)
    do
    Delay_us(100);
    a += 1;
    if(a == 0x03E8) //Hex value for 1000 in BCD
    a = 0; //Clear the vlaue to 0
    key = a;
    i = key/100; // 1st digit
    key = key%100;
    j = key/10; // 2nd digit
    key = key%10;
    k = key; // 3rd digit
    PORTC = i;
    j = j<<4;
    j = j + k;
    PORTD = j;
    Regards,
    Jerin.
  19. #19
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,367
    Points
    69,545
    Level
    64
    You will find the resulting hex file is bigger than it needs to be because of the divide and modulus instructions but the mathematics is good. 'C' compilers use libraries which can be quite large, in order to do division it will probably load the whole maths library which will result in bigger code. It is more efficient to use logic rather than arithmetic functions but if you have plenty of memory space left it isn't a problem.
    Brian.
