+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Newbie level 6
    Points: 435, Level: 4
    Join Date
    Oct 2010
    Posts
    13
    Points
    435
    Level
    How can we use Altium for RF PCB layout? For example a BIAS T. Anyone please help.
    •   Alt20th October 2010, 02:28
      advertising
  2. #2
    Advanced Member level 2
    Points: 5,187, Level: 17
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    Re: How can we use Altium for RF PCB layout? For example a BIAS T. Anyone please help
    Hope attached pdf helps
  3. #3
    Newbie level 6
    Join Date
    Oct 2010
    Posts
    13
    Points
    435
    Level
    Quote Originally Posted by Anonymous_Ricky View Post
    Thanks hips..
    Do you know how do I measure dimension ( I mean point to point) in Altium software. Again your help will be very much appreciated.
    •   Alt21st October 2010, 05:13
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    You have to first make the layer active in which you want to do measurement.
    Than it will automatically snap to point-point.
    Suppose you want to measure dimension of two lines in Top Overlay than first make top overlay active than you will get point to point measurement for those two lines.
    •   Alt21st October 2010, 16:15
      advertising
  5. #5
    Newbie level 6
    Join Date
    Oct 2010
    Posts
    13
    Points
    435
    Level
    Thanks hips...Actually I was doing it. It just that we have to click "Camtastic" on bottom if you are dealing with a Cam file in order to see the numeric value.
    Now again will be helpful, how can I add text on a Camtastic layout. Thank you again.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    I have not worked on Camtastic so cant help you on that.
    But why dont you add text in PCB itself as Camtastic is only for gerber viewing.
  7. #7
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,512
    Points
    239,598
    Level
    100
    The good think with these windows applications is, they are almost self-explanatory. Did you ever try "Place - Text" from the Camtastic menu?
  8. #8
    Newbie level 6
    Join Date
    Oct 2010
    Posts
    13
    Points
    435
    Level
    Thanks hips guyz,
    One more thing, I am importing dxf file from DWGeditor to Altium using CAMtastic editor, it seems like it’s not importing the text and also the Hatch. Is there anything I can do while importing which can fix this problem.
    Your help will be much appreciated.
    Thanks again.
    •   Alt27th October 2010, 04:48
      advertising
  9. #9
    Newbie level 6
    Join Date
    Oct 2010
    Posts
    13
    Points
    435
    Level
    Thanks hips,
    One more thing, I am importing dxf file from DWGeditor to Altium using CAMtastic editor, it seems like it’s not importing the text and also the Hatch. Is there anything I can do while importing which can fix this problem. pLEASE hELP
    Thanks again.
