need help about distance measurement using ping ultrasonic sensor and PIC16f84a
rhee2
Newbie level 2
hello everybody,, :D
I've a problems in my project,,
I want to measure distance using ping ultrasonic sensor and PIC16f84a with 4Mhz xtall and display it in 8 bit data,, when the distance is 300cm led in PORTB show ffh
I've already made the program,, but this program doesn't run well,,
the counter is reset when the distance 125cm,,
the program list is below :
#include <htc.h>
#include <pic1684.h>
unsigned char a;
unsigned char c;
/*void interrupt isr()
TMR0=0;
c=TMR0;
if(T0IF!=1)
c++;
else if(T0IF==1)
T0IF=0;
T0IF = 0; /* Clear timer interrupt */
void delay()
for(a=0; a<4; a++)
void delay2()
for(a=0; a<1; a++)
void delay1()
for(a=0; a<250; a++)
void lambat()
a=254;
while(a<255)
a++;
void main()
unsigned char d;
TRISB=0x00;
PORTB=0x00;
//OPTION=0x07;
//INTCON=0xA0;
GIE=1;
while(1)
c=0;
//TMR0=0;
//c=TMR0;
T0IF=0;
TRISA=0x00;
RA2=1;
delay();
RA2=0;
delay1();
delay1();
delay1();
RA2=1;
delay();
TRISA=0x1f;
while(TRISA==0x1f)
// INTCON=0xA0;
while(RA2==1 && c<255)
c++;
#asm
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
nop;
#endasm
//PORTB=c;
while(RA2==0)
{PORTB=c;}
delay1();
can you help me to fix this program,,,
thanks for your attention,, :D
big respect,,
I use MPLAB IDE v7.60 with compilers Hitech ANSI C compiler,,
can you help me to fix this program Mr. jerin,,
thanks before,, :D
big respect,,
