+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
  1. #1
    Points: 416, Level: 4
    Join Date
    Oct 2010
    Posts
    Points
    416
    Level
    serial communication of PIC 16F877A with pc serial port
    I am using pic 16F877A micro controller, Rs232 interface. I want to serial communication with computer to micro controller by transmitting and receiving data. I am writing code in MPLABIDE Please help me with some example programs or in any other way to improve my knowledge.
    Thanks in advance.
  2. #2
    Full Member level 3
    Points: 2,061, Level: 10
    Join Date
    Jan 2010
    kerala
    Posts
    155
    Points
    2,061
    Level
    10
    Re: serial communication of PIC 16F877A with pc serial port
    Dear kapil,
    First you study serial communication registers used in pic
    This program will help u.
    I think it's working one.
    list p=pic16f877a
    #include"p16f877a.inc"
    cblock 0x20
    r0,r1
    endc
    org00
    goto main
    org 04h
    retfie
    main bsf STATUS,5
    movlw 0x24
    movwf TXSTA
    movlw D'48'
    movwf SPBRG
    bcf STATUS,5
    movlw 0x90
    movwf RCSTA
    l1 btfss PIR1,5
    goto $-1
    bcf PIR1,5
    movf RCREG,0
    movwf TXREG
    bsf STATUS,5
    btfss TXSTA,1
    goto $-1
    bcf TXSTA,1
    bcf STATUS,5
    goto l1
    end
  3. #3
    Member level 4
    Points: 1,932, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    india
    Posts
    78
    Points
    1,932
    Level
    10
    Just start to writing program and if any difficulty then let us know.
    first start with only sending data to pc and go ahead.
    use uart to communicate and show your data on hyper terminal.
    Piyush Manavar
    1 members found this post helpful.
    •   Alt14th October 2010, 07:53
      advertising
  4. #4
    Join Date
    Oct 2010
    Posts
    Points
    416
    Level
    I had started but, i am not recieving any data on hyperterminal
  5. #5
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    india
    Posts
    78
    Points
    1,932
    Level
    10
    Just check your settings stopbits hardware and buad rates.
    and then not working go to low baudrate
    Piyush Manavar
  6. #6
    Join Date
    Oct 2010
    Posts
    Points
    416
    Level
    Quote Originally Posted by piyush manavar View Post
    Piyush Manavar
    Hello,
    Actually i had connected an led and switch to the controller, i wanted to display when switch is pressed and led to glow when we type on from keyboard, please suggest me how to write program for serial communication
    •   Alt14th October 2010, 08:22
      advertising
  7. #7
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    india
    Posts
    78
    Points
    1,932
    Level
    10
    to write this type of program go to this way
    1-initialize all necessary hardware for key detection serial communication and enable serial interrupt
    2-set baud rate and necessity settings (stopbits and frame of bytes)
    3-continuously scan the key whether it pressed or not.
    when pressed send data byte to PC
    4-you have already enable interrupt so when ever you send byte to uc from PC program calls ISR for glowing LED.
    to check that uc receiving or not data from PC you can write Eco back program in this nothing but what ever data you receive from PC just send it back to PC so that you can guaranty that you uc is receiving data.
  8. #8
    Advanced Member level 2
    Points: 3,537, Level: 13
    incomplete_jerin's Avatar
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    The code for duplex serial communication is attached along with. Just copy it in the MPLAB IDE & check.
    Also where are you planning to display the matter which you are typing? Is it just for you to simulate or to do in practical?
    Regards,
    Jerin.
    •   Alt14th October 2010, 10:08
      advertising
  9. #9
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    If you are having more doubts do check the data sheet(USART module of the controller) for the controller you are using & it is explained there.
    Regards,
    Jerin.
  10. #10
    Junior Member level 1
    Points: 620, Level: 5
    Join Date
    Sep 2010
    Posts
    16
    Points
    620
    Level
    Please i am doing a similar project only i am using PIC16f877A to connect to a bluetooth-enabled system over an RN 41 bluetooth module.i have three LM 35 sensors connected to the PIC and the PIC is meant to transmit the values it is receiving over the bluetooth to the PC.the problem is i have connected an LED to the TX pin of the PIC to indicate if it is ON but it doesn't seem to be transmitting because my LED is OFF.i have checked my connections.please i wont mind help.thanks.
    this is the code i used in the PIC:
    unsigned long int temp_res,vc;
    unsigned int vdec, vrem;
    unsigned char op[6];
    unsigned char txt[7];
    void Text_To_Usart(unsigned char *c)
    int i;
    i = 0;
    while(c[i] != 0)
    { // Send TEXT to serial port
    Usart_Write(c[i]);
    i++;
    void first_ana()
    int i,j;
    temp_res = Adc_Read(1); // Get results of AD conversion
    PORTD = temp_res; // Send lower 8 bits to PORTD
    PORTB = temp_res >> 2; //
    temp_res=4888*temp_res;
    vdec=temp_res/10000;
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    if(op[i]!=' ') // If a blank
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void sec_input()
    int i,j;
    temp_res = Adc_Read(2); // Get results of AD conversion
    PORTB = temp_res >> 2; // Send 2 most significant bits to RB7, RB6
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void third_input()
    int i,j;
    temp_res = Adc_Read(3); // Get results of AD conversion
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void main() {
    ADCON1 = 0x80; // Configure analog inputs and Vref
    TRISA = 0xFF; // PORTA is input
    TRISB = 0x3F; // Pins RB7, RB6 are outputs
    TRISD = 0; // PORTD is output
    usart_init(9600);
    do
    first_ana();
    delay_us(1000);
    sec_input();
    delay_us(1000);
    third_input();
    delay_us(1000);
    while(1);
  11. #11
    Advanced Member level 3
    Points: 5,999, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Quote Originally Posted by chicharito View Post
    int i;
    i = 0;
    while(c[i] != 0)
    Usart_Write(c[i]);
    i++;
    void first_ana()
    int i,j;
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void sec_input()
    int i,j;
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void third_input()
    int i,j;
    WordToStr(vdec,op);
    j=0 ;
    for(i=0;i<=5;i++)
    txt[j]=op[i];
    j++;
    Text_To_Usart(txt);
    usart_write(0x0a);
    usart_write(0x0d);
    void main() {
    usart_init(9600);
    do
    first_ana();
    delay_us(1000);
    sec_input();
    delay_us(1000);
    third_input();
    delay_us(1000);
    while(1);
    Can you post your circuit =)
  12. #12
    Join Date
    Sep 2010
    Posts
    16
    Points
    620
    Level
    I don't have a concise circuit.but this link is just the idea of what i am trying to do.the virtual terminal sort of replaces the bluetooth module.i ran it on proteus and it worked fine.but i am having problems with getting the correct thing on the building.i'll appreciate any help.thanks
  13. #13
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    Two thing are there for you to check here. First is the configuration of PORTA is still analog or configured as digital. Second one is the baud rate setting of the terminal & the controller. If both the rates aren't the same then the controller won't show the desired output.
    Regards,
    Jerin.
  14. #14
    Member level 1
    Points: 588, Level: 5
    Join Date
    Oct 2010
    Mexico
    Posts
    34
    Points
    588
    Level
    Is this you first UART program? If so, why don't you make an easier program just to verify that you are really transmitting?
    But, if this is not your first program, just check the answers above and verify.
  15. #15
    Join Date
    Sep 2010
    Posts
    16
    Points
    620
    Level
    Thanks for the tip guys....i'll note that.but please i just developed one small hitch.i noticed my c program on mikroC only compiles when i set the clock to 8MHZ.i have tried 4,16,20..it just won't compile.pls does anyone have an idea why that is happening?i appreciate the help.
  16. #16
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    can you pose your hitch.c here? =)
  17. #17
    Join Date
    Jun 2010
    INDIA
    Posts
    551
    Points
    3,537
    Level
    13
    If you did not save the .c file after adding to the project this would happen i.e if you did add an old .c file to the newly created project with different frequency it shows error.
    Regards,
    Jerin.
    •   Alt19th October 2010, 12:30
      advertising
  18. #18
    Newbie level 2
    Points: 346, Level: 3
    Join Date
    Jan 2011
    Posts
    Points
    346
    Level
    RN41 to PIC
    Hi, I am wondering if any of the members could help me explain how to connect the RN41 to PIC. Thanks
  19. #19
    Advanced Member level 1
    Points: 4,023, Level: 14
    Achievements:
    7 years registered
    lockman_akim's Avatar
    Join Date
    Jul 2010
    Malaysia
    Posts
    467
    Points
    4,023
    Level
    14
    xxxxxxxxxxxx
    i also provide u the source code vb2008..
    it just 1 or 0
    lockman_akim
  20. #20
    Newbie level 2
    Join Date
    Jan 2011
    Posts
    Points
    346
    Level
    Quote Originally Posted by lockman_akim View Post
    goto my website..
    thelocxresearch.tk
    Thanks a lot bro..
