+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 2
    Points: 625, Level: 5
    Join Date
    Sep 2010
    bangalore
    Posts
    48
    Points
    625
    Level
    IIP3 and 1db compression point(P1dB) of LNA
    From the nonlinearity analysis we know that there is a proportional relationship beetween iip3 and P1dB(1dB compression point).i.e., if IIP3
    is high P1dB also high.But when I simuting my LNA for various IIp3 values iam getting same P1dB.IIP3 varying from 12dBm to 19dBm but P1dB remains at -8dBm.what may be the reason.iam using cadence tool and spectre simulator.can any one help? Thanks in advance.
  2. #2
    Junior Member level 3
    Points: 2,275, Level: 11
    Join Date
    Mar 2002
    Germany
    Posts
    25
    Points
    2,275
    Level
    11
    Re: IIP3 and 1db compression point(P1dB) of LNA
    Did you use a bipolar transistor and vary the collector current and nothing else?
    •   Alt17th October 2010, 10:20
      advertising
  3. #3
    Member level 2
    Join Date
    Sep 2010
    bangalore
    Posts
    48
    Points
    625
    Level
    Quote Originally Posted by bluetooth View Post
    Iam using MOS transitor
  4. #4
    Super Moderator
    Points: 50,337, Level: 54
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,882
    Points
    50,337
    Level
    54
    Quote Originally Posted by sureshnaidu View Post
    can any one help?
    There are a lot of threads on P1dB in these EDAboard forums. Just search for it, or start with the Similar Threads below!
    •   Alt17th October 2010, 14:26
      advertising
  5. #5
    Join Date
    Mar 2002
    Germany
    Posts
    25
    Points
    2,275
    Level
    11
    P1dB is measured at output and not at input? P1dB - at output measured - should be proportional to P-DC. If this is not the case your mosfet goes into voltage saturation or current saturation and not both simultaneously. This is due to output mismatch.
    •   Alt17th October 2010, 15:37
      advertising
  6. #6
    Advanced Member level 1
    Points: 4,396, Level: 15
    prcken's Avatar
    Join Date
    Nov 2006
    Shanghai
    Posts
    420
    Points
    4,396
    Level
    15
    i think the formula P1dB=IIP3-9.6dB is derived from Taylor series analysis
    maybe in spectre simulation, the IIP3 and P1dB is derived from its transform function accordingly, not pure Taylor series.
  7. #7
    Full Member level 4
    Points: 1,744, Level: 9
    Join Date
    Jun 2010
    Belarus
    Posts
    190
    Points
    1,744
    Level
    9
    Hi
    Could you clarify more the structure of your circuit?
    What is the input power of tones in iip3 analysis?
    I think the proportional relationship appears only if we assume that coefficients of power series of transfer function don't change with input power level - it's not the case when we measure P1db - dc bias point may change significantly.
    So may be the reason of such behaviour is that during iip3 and p1db measurements input power levels seen by circuit differs very much - so there are different sources of nonlinearity.
    Regards.
  8. #8
    Member level 2
    Join Date
    Sep 2010
    bangalore
    Posts
    48
    Points
    625
    Level
    Quote Originally Posted by pavel_adameyko View Post
    Hi
    Regards.
    iam using a power level of -30dbm.the structure is common source cascode amplifier.thanks and regards.
  9. #9
    Full Member level 4
    Join Date
    Jun 2010
    Belarus
    Posts
    190
    Points
    1,744
    Level
    9
    Just for curiosity, with +12 or even +19 IIp3 you get extremely linear LNA. How much is it gain? Have you used special linearization methods?
  10. #10
    Member level 2
    Join Date
    Sep 2010
    bangalore
    Posts
    48
    Points
    625
    Level
    gain is 10dB.Derivative superposition is used for linearity improvement.input matching is provided through resistor at the gate.
    •   Alt19th October 2010, 15:19
      advertising
  11. #11
    Join Date
    Mar 2002
    Germany
    Posts
    25
    Points
    2,275
    Level
    11
    Did you measure P-DC when measuring P1dB? Is P-DC constant or raises your drain current by probably two times or three times when you raise your input RF power? I don´t know know what derivative superposition is. Can you please explain?
    Thanks.
  12. #12
    Member level 5
    Points: 2,298, Level: 11
    Join Date
    Nov 2004
    Posts
    93
    Points
    2,298
    Level
    11
    I guess the question really is "why derivative superposition (DS) does not help P1dB?"
    DS is used to cancel out the 2nd derivative of transconductance, and the P1dB is also caused by this 2nd derivative (generally). So it should help both the IP3 and P1dB, shouldn't it?
    Any follow-up?
