Howto recover wrong fuses settings on a AVR atmega8
mishra12
Advanced Member level 2
some where left alone
hi experts
How to recover wrong fuses settings on a AVR say atmega8 ? may be isp disabled (cannot detect chip error-24).don't suggest HV programmer method pls suggest any easier way to recover .
i am using pony prog2000.thanks.
STK500 development board can recover avr (in parallel high voltage programming mode)
or
Check this link
It depends on how the fuses are set.
If you had selected external crystal then this may work.
If you had disabled the spi then you need a parallel high voltage programmer
Nandhu
thanks for reply sir i think the chip is spi disabled and as you suggested i found this circuit for hvp for atmega series ,i have little confusion how to set internal crystal value from 3 -8 mhz .pls provide me screen shot for setting this option .
The circuit is a good one and restore the fuses to the default values (factory settings).
Avoid using pony prog. Better use usbasp.
For settings use fuse bit calculator software
Nandhu
For recovering fuse bits, there are various techniques discussed in this thread.
https://www.edaboard.com/threads/131804/
Find the way you find easy and working. By the way, using USBasp with ProISP as programming software works great.
thanks to all now i am gonna construct usbasp( pranam77/nandhu015)
as suggestion because easy to construct before that i'll try like welove8051 suggested using external clock source .lastly pls how to select 4mhz crystal internally is it check on cksel 1100 along with bootsz1 and bootsz0 checked
