+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 2
    Points: 5,534, Level: 17
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    some where left alone
    Posts
    666
    Points
    5,534
    Level
    17
    Howto recover wrong fuses settings on a AVR atmega8
    hi experts
    How to recover wrong fuses settings on a AVR say atmega8 ? may be isp disabled (cannot detect chip error-24).don't suggest HV programmer method pls suggest any easier way to recover .
    i am using pony prog2000.thanks.
  2. #2
    Advanced Member level 5
    Points: 13,576, Level: 28
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,961
    Points
    13,576
    Level
    28
    Blog Entries
    18
    Re: Howto recover wrong fuses settings on a AVR atmega8
    STK500 development board can recover avr (in parallel high voltage programming mode)
    or
    Check this link
    Atmega HVPP fusebit doctor – napraw fusebity, fix fusebits >> Manekinen DIY
    •   Alt1st October 2010, 11:42
      advertising
  3. #3
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    666
    Points
    5,534
    Level
    17
    can i connect to external clock source(1mhz) for recovery of atmega8 using pony prog ?
    •   Alt1st October 2010, 18:06
      advertising
  4. #4
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,961
    Points
    13,576
    Level
    28
    Blog Entries
    18
    It depends on how the fuses are set.
    If you had selected external crystal then this may work.
    If you had disabled the spi then you need a parallel high voltage programmer
    Nandhu
    •   Alt1st October 2010, 18:35
      advertising
  5. #5
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    666
    Points
    5,534
    Level
    17
    thanks for reply sir i think the chip is spi disabled and as you suggested i found this circuit for hvp for atmega series ,i have little confusion how to set internal crystal value from 3 -8 mhz .pls provide me screen shot for setting this option .
    1 members found this post helpful.
  6. #6
    nandhu015's Avatar
    Join Date
    Feb 2006
    India
    Posts
    1,961
    Points
    13,576
    Level
    28
    Blog Entries
    18
    The circuit is a good one and restore the fuses to the default values (factory settings).
    Avoid using pony prog. Better use usbasp.
    For settings use fuse bit calculator software
    Nandhu
  7. #7
    Full Member level 6
    Points: 5,004, Level: 16
    Achievements:
    7 years registered
    welove8051's Avatar
    Join Date
    Jul 2009
    india
    Posts
    354
    Points
    5,004
    Level
    16
    hi, check the post 4 of this thread by ctownsend http://www.edaboard.com/thread131804.html. it actually works i recovered 2 atmega8. use pony prog.
    •   Alt2nd October 2010, 07:26
      advertising
  8. #8
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    For recovering fuse bits, there are various techniques discussed in this thread.
    Find the way you find easy and working. By the way, using USBasp with ProISP as programming software works great.
  9. #9
    Achievements:
    7 years registered
    Join Date
    Feb 2009
    Posts
    666
    Points
    5,534
    Level
    17
    thanks to all now i am gonna construct usbasp( pranam77/nandhu015)
    as suggestion because easy to construct before that i'll try like welove8051 suggested using external clock source .lastly pls how to select 4mhz crystal internally is it check on cksel 1100 along with bootsz1 and bootsz0 checked
