+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 3
    Points: 533, Level: 4
    buiducthang's Avatar
    Join Date
    Aug 2010
    Vietnam
    Posts
    27
    Points
    533
    Level
    Plzz Help! B688 become hot!!!
    Hi everyone. I have designed a power supply with high current. I used 7805 with B688 follow this diagram:
    But in this diagram, when current is about 400mA, Transistor become hot a lot.
    I dont know why. My transistor is B688. I try using many difference resistor but it is not effect. B688 is still hot.
    Who can help solve it.
    Thanks very much.
    •   Alt1st October 2010, 08:17
      advertising
  2. #2
    Super Moderator
    Points: 70,384, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,516
    Points
    70,384
    Level
    64
    Re: Plzz Help! B688 become hot!!!
    The power dissipated in Q1 depends as much on the voltage across it as the current through it. There is no linear regulator which can defy this fundamental law of physics.
    Q1 starts to conduct when the load current is about 200mA, you could reduce R1 so more current goes through the regulator before it starts to conduct but I'm guessing your real problem is lack of heat sink. The heat dissipated by the regulator and transistor combined is (Input voltage - Output voltage) x Input current. You can't change that I'm afraid, the best you can do is get rid of the heat with a heat sink.
    Brian.
    1 members found this post helpful.
    •   Alt1st October 2010, 09:41
      advertising
  3. #3
    Join Date
    Aug 2010
    Vietnam
    Posts
    27
    Points
    533
    Level
    Quote Originally Posted by betwixt View Post
    Brian.
    Yes, u are right. We can't change the fact that: the heat is (Input voltage-Output voltage). Input Current. But Q1 is power component. Its can work with large current throught it. My problem is when the current is about 400mA, Q1 become hot. If so, this diagram is not High Current Voltage Regulator. I agree that i have to use more heat sink.
    Thanks.
    •   Alt1st October 2010, 09:55
      advertising
  4. #4
    Super Moderator
    Points: 49,672, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Quote Originally Posted by buiducthang View Post
    8A sounds like a high current to me (higher than 78xx would manage). The circuit is a high current regulator. As already pointed out, you cannot change the laws of physics and must provide the means to dissipate the power resulting from the circuit.
    Keith.
  5. #5
    Join Date
    Aug 2010
    Vietnam
    Posts
    27
    Points
    533
    Level
    Yes, Maybe we can avoid the physical law. This is linear supply voltage. So the heat either disspate in Regulator or in Q1. I think i have to use Switching Power supply.
    Thanks Bro!
    •   Alt1st October 2010, 10:41
      advertising
  6. #6
    Advanced Member level 5
    Points: 35,374, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,677
    Points
    35,374
    Level
    45
    It's probably less about the transistor, than heat sink and
    airflow. Watts is watts, and they need to go someplace
    else. Quickly.
