+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Junior Member level 2
    Points: 979, Level: 7
    Join Date
    Jun 2010
    Posts
    21
    Points
    979
    Level
    7
    Increasing the DC 5V 250 mA adopter volt & amp.
    I want transformerless power supply with 24V 2 Amp and I think any existing cell phone battery adopter can do it for me. I have an DC adopter (5V 250 mA) and want some changes in the circuit to get my desired volt & amp. You can review the circuit of any of your adopter, as most peoples has such a adopters.
    You may also suggest any other circuit that can provides me transformerless power supply with DC 24V 2 Amp.
  2. #2
    Full Member level 5
    Points: 3,233, Level: 13
    Join Date
    Oct 2005
    Posts
    253
    Points
    3,233
    Level
    13
    Blog Entries
    Re: Increasing the DC 5V 250 mA adopter volt & amp.
    have you even opened one of those mains DC adapters ? many parts are surrounded in glue. If you spend enough time
    you might identify the feedback resistor divider network and alter the values for a different output voltage.
    But there is no way you will at the same time increase the current rating.
    5V @ 250ma is 1.25Watts, you can't magically make such a supply deliver 24V@2amps = 48Watts.
    None of the components in it will be rated for that power capability.
    6 members found this post helpful.
    •   Alt20th September 2010, 01:03
      advertising
  3. #3
    Newbie level 5
    Points: 1,930, Level: 10
    Achievements:
    7 years registered
    Join Date
    Mar 2008
    Pasig City Philippines
    Posts
    10
    Points
    1,930
    Level
    10
    Quote Originally Posted by crazybuoy View Post
    chargers have a transformer w/c is a switching transformer,you can only achieve 24V with 2A using flyback topology SMPS using an input of AC mains(offline).main advantage of this topology is isolated,the input is not connected with output because of switching transformer.you can use link below for reference.
    http://www.fairchildsemi.com/an/AN/AN-4137.pdf
    but if you still want an offline power supply but without transformer,you can use non-isolated but this is not a high current output but this can be use to power-up low power devices such as microncontroller.link below for references.
    http://ww1.microchip.com/downloads/e...tes/00954A.pdf
    regards,
    spectrum17
    3 members found this post helpful.
  4. #4
    Join Date
    Jun 2010
    Posts
    21
    Points
    979
    Level
    7
    How about to use big resistor to drop the 220v AC to 24v AC then use bridge rectifier to convert it to DC?
  5. #5
    Newbie level 5
    Achievements:
    7 years registered
    Join Date
    Mar 2008
    Posts
    10
    Points
    1,930
    Level
    10
    this is acceptable,however it is only applicable for low power applications,but it is not efficient and not isolated.with step-down transformer is always a good design and safe to use.
    regards,
    spectrum17
    1 members found this post helpful.
  6. #6
    Newbie level 3
    Points: 427, Level: 4
    Join Date
    Sep 2010
    abbottabad
    Posts
    Points
    427
    Level
    my project is 48v to 12 v buck converter in continuous conduction mode using matlab simulink.but it is difficult to me to make a simulink model of PWM which hass as out put duty cycle 0.12.can some body help me plz?
  7. #7
    Newbie level 5
    Achievements:
    7 years registered
    Join Date
    Mar 2008
    Posts
    10
    Points
    1,930
    Level
    10
    Quote Originally Posted by qa majid View Post
    maybe you can use SIMetrix from Catena and PSIM to simulate buck converters to tailor your compensation needs.
    Analog Circuit Simulation Software from SIMetrix Technologies - SPICE
    PSIM Software by Powersim Inc
    •   Alt6th October 2010, 06:57
      advertising
  8. #8
    Junior Member level 1
    Points: 988, Level: 7
    Join Date
    Jan 2008
    Posts
    19
    Points
    988
    Level
    7
    Why do u want to use the DC adaptor anyway.
    Use power electronic converters if u wish to directly convert AC to DC.
    Advantage will be that the circuit will be small in size and will not be too much complex.
    Read about thyristor (SCR) and the related devices in family.
    browse journals for design specific for your requirement. u can also
    refer to this:
    http://www.nxp.com/documents/applica...te/APPCHP6.pdf
  9. #9
    Member level 5
    Points: 2,090, Level: 10
    Qube's Avatar
    Join Date
    Nov 2010
    Posts
    80
    Points
    2,090
    Level
    10
    I think the resistor may get very heated up,it may need high watt rated resistor for this purpose...wat do u think??
    And it's also not that much safe when compared to transformer...u can't use it for a long time..
  10. #10
    Member level 5
    Points: 2,694, Level: 12
    qayyoum's Avatar
    Join Date
    Apr 2006
    PakistaN
    Posts
    80
    Points
    2,694
    Level
    12
    hi ( xaccto ) you are right that supply not able to provide 48 watt(2 amp)
    please must be see this link you understand how to convert smps volt complite technical information
    (Smps Voltaj)
    2 members found this post helpful.
  11. #11
    Member level 1
    Points: 1,413, Level: 8
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Russia
    Posts
    32
    Points
    1,413
    Level
    8
    You can use big resistor or big capacitor to drop 220 V to 24 V AC, but he must dissipate (220V - 24V)*2A = 392 Watt of heat.
    If you want use transformerless power supply, you can get about 0.1 A maximum (from this transformerless circuit, replace VD3 to 24 V 0.5 W zener diode).
    If you find cheapest solution for 24 V 2 A hobby power supply, you can use this SMPS circuit, after replace T1 to POL24020 and D1 to TOP226 (use radiator for D1 and VD5).
    •   Alt1st December 2010, 08:25
      advertising
  12. #12
    Advanced Member level 1
    Points: 5,189, Level: 17
    grittinjames's Avatar
    Join Date
    Jun 2006
    bangalore india
    Posts
    480
    Points
    5,189
    Level
    17
    Please visit Powerint.com
    You will get many usefull circuit
    Grittin
  13. #13
    Newbie level 2
    Points: 697, Level: 5
    Join Date
    Feb 2009
    Posts
    Points
    697
    Level
    this is good website for more details
  14. #14
    Newbie level 3
    Points: 1,038, Level: 7
    Join Date
    Aug 2009
    India
    Posts
    Points
    1,038
    Level
    7
    24V/250ma adapter is designed for 6 watt and you want 24V and 2 amp which is 48 watt. So there is a big deference. This is not possible use the same adapter for your purpose. you need a new design altogether.
  15. #15
    Full Member level 5
    Points: 2,342, Level: 11
    Jigar 4 Electronics's Avatar
    Join Date
    Apr 2011
    Hamilton, ON, Canada
    Posts
    313
    Points
    2,342
    Level
    11
    Blog Entries
    Quote Originally Posted by war4one View Post
    Can you tell me which value of the resistor and capacitor I should use to do this.
    I wanna make that without transformer for my very small circuit which is also a low power circuit.
    I have 220V AC 50Hz and want 5 V DC.
    But better you tell me how to calculate the value of R & C to get XYZ Volt DC o/p.
    Never Leave it until you did it.
    Every time you fails go for one more time :)
  16. #16
    Points: 85, Level: 1
    Join Date
    Jul 2012
    Posts
    Points
    85
    Level
    HI,How about the power module converter for the electronic parts?
