+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 3
    Points: 1,176, Level: 7
    Join Date
    Aug 2009
    Posts
    61
    Points
    1,176
    Level
    7
    Creating A New Component (DLL) For Proteus VSM
    Hello all!
    I have just started creating components for Proteus VSM and am having some troubles with the coding. I have gotten a basic digital decive to work and now am working on a combo V/A meter with animations to get the hang of graphics but I can only display info from RTVPROBE or RTIPROBE but not both at the same time.
    Does anybody know how to do this? Under my new device 'Primitive' I have 'ANALOG, RTVPROBE' or "ANALOG, RTIPROBE' but it will not let me use 'ANALOG, RTVPROBE, RTIPROBE' which I think I will need. Or do I need to do the calculations based off spice input by hand?
    Here is my code:
    #include <windows.h> // All windows apps need this
    #include <stdio.h>   // printf() & scanf() functions
    #include <math.h>    // fabs() and others
    #include "VSM.HPP"
    class UM_METER : public IACTIVEMODEL
    	public:
          VOID initialize (ICOMPONENT *cpt);
          ISPICEMODEL *getspicemodel (CHAR *device);
          IDSIMMODEL *getdsimmodel (CHAR *device);
          VOID plot (ACTIVESTATE state);
          VOID animate (INT element, ACTIVEDATA *newstate);
          BOOL actuate (WORD key, INT x, INT y, DWORD flags);
    	private:
          ICOMPONENT *component;
          POINT volts;
    	  POINT amps;
          HTEXTSTYLE textstyle;
          CHAR readout_v[10];
    	  CHAR readout_a[10];
    // The create & delete functions, Ignore licencing authorization to make components avalible to any licence
    extern "C" __declspec(dllexport) IACTIVEMODEL *createactivemodel (CHAR *device, ILICENCESERVER *ils) { return new UM_METER; }
    extern "C" VOID __declspec(dllexport) deleteactivemodel (IACTIVEMODEL *model) {	delete (UM_METER *)model; }
    VOID UM_METER::initialize (ICOMPONENT *cpt)
    // Store ICOMPONENT interface and initialize.
       component = cpt;
       // Get entire component(-1) origin
       BOX textbox;
       cpt->getsymbolarea(-1, &textbox);
       // Do some math to position the readouts properly
       volts.x = (textbox.left+textbox.right)/2;
       volts.y = (textbox.top+textbox.bottom)/2-100;
       amps.x = (textbox.left+textbox.right)/2;
       amps.y = (textbox.top+textbox.bottom)/2+100;
       // Create a new text style in 'Templates' menu or other objects get funky
       // Still makes other meters readouts conform to his style, how to use properly??
       textstyle = cpt->createtextstyle("UM_METER");
       // Initial readout:
       strcpy(readout_v, " 00.0");
       strcpy(readout_a, " 0.00");
    VOID UM_METER::plot (ACTIVESTATE state)
    // This is called to display the component when not simulating
    	// Draw entire component on the screen
    	component->drawsymbol(-1);
    	// Draw symbol 0 overtop components
        component->drawsymbol(0);
    	// Place the default readouts on the screen
        component->drawtext(volts.x, volts.y, 0, TXJ_CENTRE|TXJ_MIDDLE, readout_v);
    	component->drawtext(amps.x, amps.y, 0, TXJ_CENTRE|TXJ_MIDDLE, readout_a);
    VOID UM_METER::animate (INT element, ACTIVEDATA *data)
    // Animate function - this is called whenever an event is
    // produced by the simulator model.
    	// Check which element has called for an update
    	//       Element ID is    N/A ,   0    ,    1
    	// Device primitive is "ANALOG,RTVPROBE,RTIPROBE"
    	if (element == 0) // Volts
    		DOUBLE absval = fabs(data->realval);
    		CHAR sign;
    		CHAR result[10];
    		// Decide whether to prefix with  a +, a - or nothing:
    		if (data->realval > 0.001)
    			sign = '+';
    		else if (data->realval < -0.001)
    			sign = '-';
    		else
    			sign = ' ';
    		// Now we work out where to place the decimal point:
    		if (absval >= 1000)
    			sprintf(result, "%cMAX", sign);
    		else if (absval >= 100)
    			sprintf(result, "%c%3.0f", sign, absval);
    		else if (absval >= 10)
    			sprintf(result, "%c%4.1f", sign, absval);
    		else
    			sprintf(result, "%c%4.2f", sign, absval);
    		// Store the new value
    		strcpy(readout_v, result);
    	if (element == 1) // Amps
    		CHAR sign;
    		CHAR result[10];
    			sign = '+';
    			sign = '-';
    		else
    			sign = ' ';
    		if (absval >= 1000)
    		else
    		strcpy(readout_a, result);
    	// Re-draw the displayed value with the new results
    // As the class is 'abstract' you must impliment ALL functions even if they are not used!
    ISPICEMODEL *UM_METER::getspicemodel (CHAR *) { return NULL; }
    IDSIMMODEL  *UM_METER::getdsimmodel  (CHAR *) { return NULL; }
    BOOL UM_METER::actuate (WORD key, INT x, INT y, DWORD flags)  { return FALSE; }
    •   Alt19th September 2010, 07:09
      advertising
  2. #2
    Banned
    Points: 293, Level: 3
    Join Date
    Jun 2012
    Posts
    41
    Points
    293
    Level
    Re: Creating A New Component (DLL) For Proteus VSM
    Hello!
    Can you upload the file VSM SDK. I need the following files.
    vsm.hpp
    vdm.hpp
    vdmpic.hpp
    vdm11.hpp
    vdm51.hpp
    Thanks
    Jayanth D
    •   Alt15th June 2012, 17:13
      advertising
  3. #3
    Full Member level 6
    Points: 4,204, Level: 15
    Join Date
    Sep 2001
    Posts
    324
    Points
    4,204
    Level
    15
    Please check the attachment.
