Pls help : WSN simulation tools focussing at node level
hikaan
Junior Member level 2
Hi ,
I am started doing the research work based on wireless sensor network. in which i am concentrating at node level. is there any tool available to know and change the properties of the sensor node.so that i am able to improve the lifetime / enhance the performance of the sensor network.
Thanks
g kannan
What has happened Hikaan?
It will be great if you can share your experience?
which software you found better/ which one you have chosen?
    V
