+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Advanced Member level 1
    Points: 10,571, Level: 24
    Join Date
    Dec 2001
    Posts
    414
    Points
    10,571
    Level
    24
    555 power supply
    a 150W switchmode power supply with 555 timer:
    it cheapest method to design such switch mode power supply.
    •   Alt24th May 2004, 06:32
      advertising
  2. #2
    Full Member level 3
    Points: 3,105, Level: 13
    Ante's Avatar
    Join Date
    May 2004
    Posts
    169
    Points
    3,105
    Level
    13
    555 smps
    March 1977, you must be kidding. I it 2004 now, get real!
    Ante
  3. #3
    Newbie level 1
    Points: 4,882, Level: 16
    Join Date
    Jun 2002
    Posts
    Points
    4,882
    Level
    16
    ka3525 circuit
    in 2004,we can advanced chip(like 3842,....),but 555 chip is cheapest!
    1 members found this post helpful.
  4. #4
    Full Member level 5
    Points: 3,982, Level: 14
    Join Date
    Mar 2002
    Posts
    253
    Points
    3,982
    Level
    14
    homemade switching power supply
    the fundamental behind the most of SMPSes are the same but the advances in technology provide lower cost, efficient and feature rich chips which integrate all of the power electronincs circuits in a single die or package (hybrids).
    currently several manufacturers provide integrated switchers/regulators with this range of power or upper; BTW the circuit is useful as a home made DC to DC convertor.
    BEST!
  5. #5
    Junior Member level 3
    Points: 2,473, Level: 11
    Join Date
    Jan 2000
    Posts
    29
    Points
    2,473
    Level
    11
    ka3525 application
    This 'simple' step down converter is one of the most expensive I ever seen. (1977 it's ok, but today too expensive)
    This regulator has a poor efficiency. I think the losses in the switching Darlington transistor are > 10W. So you are in need to cool it well with a very expensive and BIG heat sink !!! A mechanical disaster.
    Modern concepts are much cheaper. They work with MOSFETs and do not need heatsinks to be cooled.
    felix1200
    •   Alt30th May 2004, 10:16
      advertising
  6. #6
    Full Member level 6
    Points: 4,300, Level: 15
    Join Date
    Oct 2002
    India
    Posts
    324
    Points
    4,300
    Level
    15
    smps 555
    8) i have used 555 timer in low power DC DC converter application, works fine but has many limitations. 1; have to add external referances 2: add external drive elements 3: limited sypply voltage range. 4:external components required for current limiting .
    way back in 77 the price of SMPS controllers where high and people where experimenting using other available IC s.
    but now the price of 555 , SG3524, TL494 or UC 3842 are almost equal. there is no point in designing using Timer IC.
  7. #7
    Full Member level 3
    Ante's Avatar
    Join Date
    May 2004
    Posts
    169
    Points
    3,105
    Level
    13
    555 switching power supply
    The 555 is cool but not for this application! And look 8O at some of the other stuff, transistors, diodes, PUT and more. They are gonners in an app like this, maybe not even possible to get hold of.
    Ante
    •   Alt30th May 2004, 21:11
      advertising
  8. #8
    Full Member level 3
    Points: 3,086, Level: 13
    batdin's Avatar
    Join Date
    Jun 2004
    Bulgaria
    Posts
    182
    Points
    3,086
    Level
    13
    555 timer power supply
    It sounds to me like "Rocket-engine powered dragster using cart wheels".
    Call me ultramodern but I prefer KA3525 ;)
    If everything looks fine,there must be something very wrong here.
  9. #9
    Join Date
    Dec 2001
    Posts
    414
    Points
    10,571
    Level
    24
    lm555 with smps
    Ka3525 for halfbridge,
    I think Uc3843 for forward topology power supply is better.
  10. #10
    Full Member level 6
    Points: 3,962, Level: 14
    metal's Avatar
    Join Date
    Dec 2004
    Posts
    364
    Points
    3,962
    Level
    14
    power supply 555
    Hello Everybody
    I don't know why people think its shame to use old or cheap stuff to acomplish a job, the guy just wanted to share a nice circuit, in deed, the UC3843 is not available in my country, so Such people like me will consider such circuit of great help.
    Anyway,ITS UP TO THE CONSTRUCTOR whether to use new, old or even discontinued products. My self, I have used the µPC1225H to build an audio power amplifier of 60 watts output. Its performance was great, although its a continued one and really old one.
    No hard feelings
    Regards
  11. #11
    Advanced Member level 3
    Points: 9,269, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    uc3843 power supply
    Good one!!
    We should think about improving this circuit by replacing switching transiotor
    by power MOSFET!
    •   Alt29th December 2004, 12:24
      advertising
  12. #12
    Full Member level 3
    Points: 2,103, Level: 10
    Join Date
    Oct 2004
    Posts
    174
    Points
    2,103
    Level
    10
    ka3525 schematic
    i think we should improve effcient.
  13. #13
    Full Member level 6
    metal's Avatar
    Join Date
    Dec 2004
    Posts
    364
    Points
    3,962
    Level
    14
    uc3843 power supply schematic
    Hello
    Concerning the MOSFET, I think there is no need to use it, as long as the switching frequency is not too high. So as not to raise the cost, for being cost effective.
    Regards
  14. #14
    Newbie level 1
    Points: 987, Level: 7
    Join Date
    Jun 2007
    Posts
    Points
    987
    Level
    7
    homemade switch mode power supply
    Hi, friends
    Anyone can please send me some SMPS schemmatic, I´m working in a project like these. Thanks!
  15. #15
    Newbie level 1
    Points: 1,060, Level: 7
    Join Date
    Jun 2007
    Posts
    Points
    1,060
    Level
    7
    ka3525 application note
    I made an alternative link on my server.
    Hope that helps!
    150_Watt smps.pdf
