+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 2
    Points: 1,908, Level: 10
    Join Date
    Dec 2005
    Posts
    120
    Points
    1,908
    Level
    10
    F microstrip antenna in CST and HFSS.Please help
    Hi eveyone
    I am simulating F microstrip antenna in CST and HFSS. Drawing it in CST and HFSS is simple .But I do not know how to put the port to run the transient solver in this. Is this lumped port( discrete port) or waveguide port to get the good simulation. In HFSS I do not know how to put the port because the feeding lie inside the antenna. I post my picture with this question and hope there are someone have answer for me
    ---------- Post added at 10:12 AM ---------- Previous post was at 10:01 AM ----------
  2. #2
    Newbie level 6
    Points: 982, Level: 7
    Join Date
    Jul 2008
    india
    Posts
    11
    Points
    982
    Level
    7
    Re: F microstrip antenna in CST and HFSS.Please help
    Hi bkd
    where is the picture...?
    1 members found this post helpful.
    •   Alt27th August 2010, 11:53
      advertising
  3. #3
    Member level 4
    Points: 1,713, Level: 9
    Join Date
    Dec 2006
    Posts
    68
    Points
    1,713
    Level
    9
    hi
    isert dimension and the shape of the structure.
    if not, there is a lot of helpful examples in eda forum
    good luk
  4. #4
    Full Member level 2
    Join Date
    Dec 2005
    Posts
    120
    Points
    1,908
    Level
    10
    here the picture
    F antenna | Flickr - Photo Sharing!
    ---------- Post added at 03:51 PM ---------- Previous post was at 03:47 PM ----------
    •   Alt27th August 2010, 16:51
      advertising
  5. #5
    Full Member level 2
    Join Date
    Dec 2005
    Posts
    120
    Points
    1,908
    Level
    10
    Here the port I design in HFSS. But the result is so different from CST. I doubt that it not correct port setting . Is there anyone help
    F antenna1 | Flickr - Photo Sharing!
  6. #6
    Member level 4
    Join Date
    Dec 2006
    Posts
    68
    Points
    1,713
    Level
    9
    unfortunately
    flickr.com is not working in our country !!!!!
  7. #7
    Full Member level 2
    Join Date
    Dec 2005
    Posts
    120
    Points
    1,908
    Level
    10
    IS there anyone help
  8. #8
    Newbie level 6
    Join Date
    Jul 2008
    india
    Posts
    11
    Points
    982
    Level
    7
    Hi
    I am not able to properly see the antenna, can you upload HFSS ( 11 ) file or some more antenna diagrams.....
  9. #9
    volker_muehlhaus
    I can see the image. I often use this lumped port configuration with other EM software. It should work fine.
    •   Alt30th August 2010, 11:12
      advertising
  10. #10
    Member level 2
    Points: 1,079, Level: 7
    Join Date
    Apr 2010
    Posts
    44
    Points
    1,079
    Level
    7
    in CST, pick a point on your feed port, link it to the body ground with a discrete port. and run the transient solver. that's all
