MSP430 Programming :Error in Downlaoding program
KSHATRIYA
Member level 1
Hii all,
I am very new to MSP430,I recently had to shift to it .I have done programming on AVR .I am using MSP430 USB-Debug-Interface to download program onto MSP430 Evaluation board (MSP-FET430U64) ,I am using IAR Embedded Workbench IDE.Seeing the tutorials there I compiled the code but when I am pressing the Option
(Download and Debug ) ,I am getting an error.I have attached the screenshot of the error.
Also I have a doubt does IAR-IDE produce a hex file that has to be downlaoded on to the MSP,and other tutorial which would give better grasp of the entire process of MSP430 .
Thanks In Advance
Regards
Kshatriya
Hello!
It's very difficult to help you because this is likely to be a hardware problem.
Is the processor powered? Are you sure of the JTAG connection (supposing you made your own board)?
Just in case it's your own hardware, did you connect pin 8 from JTAG (TEST)? It was not necessary
in earlier devices (e.g. F16x), but it is necessary for the latest devices (e.g. F5x)…
Dora.
