Coaxial cables do not provide 100% shielding, so theoretically, if you wind several turns of copper wire around it and use a sensitive detector you may be able to “read” signals transmitted via the coax core ..
That’s theory ..
In practice, it will depend on a lot of factors such as signal magnitude, external noise and so on ..
