+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Member level 1
    Points: 839, Level: 6
    Join Date
    Feb 2010
    Posts
    39
    Points
    839
    Level
    floating point divider vhdl code or full architecture
    HI my friends
    I need a floating point divider to use as a part of a bigger divider,anyway i seriously need a floating point divider vhdl code(especially designed in ieee fp number format) or a detailed and simple block diagram that i can implement it in vhdl easily(or at least not in a long time).i found a vhdl code and a library in edaboard,but they werent very usefull.
    please,someone can help me and send a vhdl code(especially for ieee fp numbers format) or block diagram or a good document.
    thanks.
  2. #2
    Advanced Member level 5
    Points: 35,870, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    Xilinx and Altera both provide floating point IP cores.
    Other than that, try looking on opencores.org
  3. #3
    Full Member level 6
    Points: 3,477, Level: 13
    Achievements:
    7 years registered
    vipinlal's Avatar
    Join Date
    Mar 2010
    India
    Posts
    354
    Points
    3,477
    Level
    13
    Re: floating point divider vhdl code or full architecture
    I think there is a floating point package available.I guess it supports division for ieee format .
    The name of the package is float_pkg_c.vhd
    Download it from here:
    http://www.vhdl.org/fphdl/
    Also you can documentation about the package from the same site.
    --vipin
    http://vhdlguru.blogspot.com/
    •   Alt29th July 2010, 08:46
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    You wont get any good synthesis results from the floating point package.
  5. #5
    Member level 1
    Join Date
    Feb 2010
    Posts
    39
    Points
    839
    Level
    thanks.
    I need a code or architecture that doesn't be complicated.packages are not described full in their document and i couldn't understand how they work exactly.
    anyone has not a code that be written by him self or herself as a project???or an architecture that i can write a structural code for it.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    But floating point is complicated.
    The altera documentation is pretty good - its in the help.
  7. #7
    Super Moderator
    Points: 241,412, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,904
    Points
    241,412
    Level
    100
    More or less. Regarding FP division, I think the divsion part is more complicated than the additional normalization/denormalization action involved with floating point. Seriously, you can't manage it without understanding the details. Among various free VHDL floating point codes available on the internet, I would particularly suggest "FPU100" from opencore.org arithmetic core projects and sourceforge "libhdlfltp". Both have detailed documentation.
    The IEEE float libraries are good for the basic float handling, but, as said, not actually synthesizable, because they miss any pipeline action that would be required for reasonable speed.
    1 members found this post helpful.
  8. #8
    Member level 1
    Join Date
    Feb 2010
    Posts
    39
    Points
    839
    Level
    thank you FvM
    and other suggestions??!!!
  9. #9
    Member level 1
    Join Date
    Feb 2010
    Posts
    39
    Points
    839
    Level
    i couldn't use fpu100.
    i have all of the fpu100 files in a folder an my top level is fpu.vhd,but when i run it in quartus II,indicate an error "can't find fpupack or comppack in working directory".
    do you know what is the problem.
    also i changed the fpu to seperate parts,adder,divider,...,then used them,but again it didn't work.
    i have attached my divider,would you check it and tell me what did i do wrong???
    •   Alt3rd August 2010, 10:53
      advertising
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    Yes - Quartus is looking for fpupack.vhd and comppack.vhd. They are not there. althought they dont appear to be required.
    I would put these back in the project.
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,904
    Points
    241,412
    Level
    100
    The most simple way is to include all required design files with your project.
    Basically you have to know where the design compilers searches for files, how you set up libraries and packages.
    The problem hasn't to do with the FPU project, I think.
  12. #12
    Full Member level 5
    Points: 3,441, Level: 13
    shitansh's Avatar
    Join Date
    Jan 2009
    India-Gujarat
    Posts
    296
    Points
    3,441
    Level
    13
    You can use Convergence (Functional Iteration) Algorithms for division.
    Then using this algo try to make matlab code and prove your algo once you get correct result then you can easily write synthesizable code for that.
    HTH
    Shitansh Vaghela
  13. #13
    Newbie level 2
    Points: 565, Level: 5
    Join Date
    Nov 2009
    Posts
    Points
    565
    Level
    Do you have the code with you?the matlab code and vhdl code?
  14. #14
    Newbie level 5
    Points: 877, Level: 6
    Join Date
    Feb 2012
    Portugal, Lisbon
    Posts
    8
    Points
    877
    Level
    I have this simple code i have writen for floating point addition, subtraction, multilication, division and square root. I will post it here the code for division:
    -- Company: Instituto Superior Técnico
    -- Prof: Paulo Alexandre Crisóstomo Lopes
    -- paulo.lopes@inesc-id.pt
    -- Create Date: 21:12:41 01/05/2012
    -- Design Name:
    -- Module Name: divider - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Description: VHDL implementation of a 32 bit floating divider.
    -- Float format: sign | 8 bits exponent + 127 | 23 bits normalized mantissa.
    -- Uses IEEE 754-1985, with the following exceptions.
    -- NaN is not implemented. Operations that would result in NaN
    -- have a non definied result.
    -- An exponent of all zeros will always mean zero, and an
    -- exponent of all ones will always mean infinity.
    -- Rounding is round nearest ties away from zero.
    -- Non normalized numbers are not implemented.
    -- Dependencies:
    -- Revision:
    -- Revision 1.0
    -- Additional Comments:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use ieee.std_logic_unsigned.all;
    -- use STD.textio.all; -- basic I/O
    -- use IEEE.std_logic_textio.all; -- I/O for logic types
    entity divider is
    Port ( x : in STD_LOGIC_VECTOR (31 downto 0);
    y : in STD_LOGIC_VECTOR (31 downto 0);
    z : out STD_LOGIC_VECTOR (31 downto 0));
    end divider;
    architecture Behavioral of divider is
    begin
    process(x,y)
    variable x_mantissa : STD_LOGIC_VECTOR (22 downto 0);
    variable x_exponent : STD_LOGIC_VECTOR (7 downto 0);
    variable x_sign : STD_LOGIC;
    variable y_mantissa : STD_LOGIC_VECTOR (22 downto 0);
    variable y_exponent : STD_LOGIC_VECTOR (7 downto 0);
    variable y_sign : STD_LOGIC;
    variable z_mantissa : STD_LOGIC_VECTOR (22 downto 0);
    variable z_exponent : STD_LOGIC_VECTOR (7 downto 0);
    variable z_sign : STD_LOGIC;
    variable a : STD_LOGIC_VECTOR (25 downto 0);
    -- holds the result of the division of the mantissas
    -- a = a0.a-1a-2a-3... a<2 e a>1/2
    -- 0 to -23 if a0=1 and -1 to -24 if a0=0. a-25 to round.
    variable partial_remainder : STD_LOGIC_VECTOR (24 downto 0);
    -- the partial remainder requires one extra bit for the shift left
    -- P = partial_remainder = xx.xxxx ... < 4
    variable tmp_remainder : STD_LOGIC_VECTOR (24 downto 0);
    variable exponent_aux : STD_LOGIC_VECTOR (8 downto 0);
    -- nine bits = 8+1 to detect underflow and overflow
    begin
    x_mantissa := x(22 downto 0);
    x_exponent := x(30 downto 23);
    x_sign := x(31);
    y_mantissa := y(22 downto 0);
    y_exponent := y(30 downto 23);
    y_sign := y(31);
    z_sign := x_sign xor y_sign;
    if (y_exponent="11111111") then -- x/inf = 0
    z_exponent := "00000000";
    z_mantissa := (others=>'0');
    else
    if (y_exponent=0 or x_exponent=255) then -- result = infinity
    -- x/0 or inf/x = inf
    z_exponent := "11111111";
    else
    exponent_aux := ('0' & x_exponent) - ('0' & y_exponent) + 127;
    partial_remainder := "01" & x_mantissa; -- P = 1.F1
    -- Area with a comparator: 1,851 4 input LUT
    -- Area joining comparacion and subtraction: 1,324 4 input LUT
    digit_loop: for i in 25 downto 0 loop
    tmp_remainder := partial_remainder - ("01" & y_mantissa);
    if ( tmp_remainder(24)='0' ) then
    -- result is non negative: partial_remainder >= ("01" & y_mantissa)
    -- note that tmp_remainder < 2 so bit 24 should be zero
    a(i):='1';
    partial_remainder := tmp_remainder;
    else
    a(i):='0';
    end if;
    partial_remainder := partial_remainder(23 downto 0) & '0'; -- sll
    -- P/2 < y && y < 2 => P < 4
    end loop digit_loop;
    a := a + 1; -- round
    if (a(25)='1') then -- a=1.xxxx
    z_mantissa := a(24 downto 2);
    else -- a=0.1xxxx
    z_mantissa := a(23 downto 1);
    exponent_aux := exponent_aux - 1;
    end if;
    -- z_exponent > 0-254+127-1 = -128 = 1 1000 0000 b
    -- y_exponent = 255 is infinity that was previously taken care
    -- z_exponent < 255-0+127 = 382 = 1 0111 1110 b
    if (exponent_aux(8)='1') then
    if (exponent_aux(7)='1') then -- underflow
    else -- overflow
    end if;
    else
    z_exponent := exponent_aux(7 downto 0);
    end if;
    end if;
    end if;
    z(22 downto 0) <= z_mantissa;
    z(30 downto 23) <= z_exponent;
    z(31) <= z_sign;
    end process;
    end Behavioral;
  15. #15
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    this code is pretty useless for a synthesised design (unless you dont mind a very very very slow design.
    For a start - wheres the clock?
    •   Alt2nd February 2012, 19:25
      advertising
  16. #16
    Newbie level 5
    Join Date
    Feb 2012
    Portugal, Lisbon
    Posts
    8
    Points
    877
    Level
    You could add a pipeline to the code if you wont.
  17. #17
    Newbie level 2
    Points: 147, Level: 1
    Join Date
    Mar 2012
    Posts
    Points
    147
    Level
    hi, i am also working on floating point alu & not getting proper output . please if u have floating point alu vhdl code ,please send it on my email id (prashant.khairnar17@gmail.com).
  18. #18
    Newbie level 2
    Points: 412, Level: 4
    Join Date
    Sep 2010
    Posts
    Points
    412
    Level
    Hi Paulo
    Do you have the similar code for square root of 32 bit IEEE754 floating point. I have written a small function which can do unsigned square root.
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    -- unsigned square root function
      function sqrt (vin : unsigned)
        return unsigned is
          variable v_in    : unsigned(31 downto 0) := vin;  -- original input
          variable v_out   : unsigned(15 downto 0) := (others => '0');  -- result
          variable i_left  : unsigned(17 downto 0) := (others => '0');  -- input to adder
          variable i_right : unsigned(17 downto 0) := (others => '0');  -- input to subtractor
          variable remd    : unsigned(17 downto 0) := (others => '0');  -- remainder
          variable i       : integer:=0;
        begin
          for i in 0 to 15 loop
            i_right(0) := '1';
            i_right(1) := remd(17);
            i_right(17 downto 2) := v_out;
            i_left(1 downto 0)   := v_in(31 downto 30);
            i_left(17 downto 2)  := remd(15 downto 0);
            v_in(31 downto 2)    := v_in(29 downto 0);  -- shifting by 2 bit
            if (remd(17) = '1') then
              remd := i_left + i_right;
            else
              remd := i_left - i_right;
            end if;
            v_out(15 downto 1) := v_out(14 downto 0);
            v_out(0) := not remd(17);
          end loop;
        return v_out; -- result
      end function sqrt;
  19. #19
    Newbie level 2
    Join Date
    Sep 2010
    Posts
    Points
    412
    Level
    Hi Paulo,
    I saw your previous post regarding square root of IEEE754 floating point
    http://www.edaboard.com/thread205274.html
    I will pipeline the design for divider and square root logic.
    Thanks
    KS
  20. #20
    Newbie level 6
    Points: 117, Level: 1
    Join Date
    Nov 2012
    Posts
    13
    Points
    117
    Level
    Quote Originally Posted by Paulo A. C. Lopes View Post
    -- Design Name:
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Dependencies:
    -- Revision:
    -- Revision 1.0
    library IEEE;
    entity divider is
    end divider;
    begin
    process(x,y)
    begin
    x_sign := x(31);
    y_sign := y(31);
    else
    else
    a(i):='1';
    else
    a(i):='0';
    end if;
    else -- a=0.1xxxx
    end if;
    else -- overflow
    end if;
    else
    end if;
    end if;
    end if;
    z(31) <= z_sign;
    end process;
    end Behavioral;
    I tried with this code but i am not getting correct answers.can u tel me the reason?
