elahetal
Junior Member level 1
hello everybody,
I have some trivial questions for you.....
Suppose using a gate driver like IR2110 to drive power mosfet:
1)to change the VGS, I have to change Vcc?
If yes, can I use different Vcc for drive HO and LO independantly?
2)In datasheet, it has mentioned the IR2110 is used to drive gate voltage between 10-20....it means that I can't apply VGS less than 10 to my mosfet and then I have to change my driver?
Thanks for your help,
Ela
P.S.My field is not power electronics but I need to learn it for part of my task.
Ela
