write2rammy
Newbie level 6
Hi all,
I am using a generate statement to instantiate a delay module (cur_starved_delay) 11 times. The basic idea is to model a 11 stage ring oscillator using current starved delay cell. But i get syntax error in generate statement. Can anyone help me with this. The code is attached below.
`include "constants.vams"
`include "disciplines.vams"
module cur_starved_delay (Vin,Vbias_p,Vbias_n,Vdd,Vss, Vout);
parameter real C_load = 1e-12;
parameter real Kp = 1;
parameter real Kn = 1;
parameter real Vt = 0.2;
parameter real pos_tol = 0.2;
parameter real neg_tol = -0.2;
input Vin,Vbias_p,Vbias_n,Vdd,Vss;
output Vout;
voltage Vin,Vbias_p,Vbias_n,Vdd,Vss,Vout;
voltage V_swing,Vsg_p,Vgs_n;
current I_p,I_n;
real Td_p,Td_n,V_ph;
analog begin
V(V_swing) <+ V(Vdd) - V(Vss);
V(Vsg_p) <+ V(Vdd) - V(Vbias_p);
V(Vgs_n) <+ V(Vbias_n) - V(Vss);
I(I_p) <+ Kp*pow((V(Vsg_p) - Vt),2);
I(I_n) <+ Kn*pow((V(Vgs_n) - Vt),2);
if ((V(Vin) <= V(Vss) + pos_tol) && (V(Vin) >= V(Vss) - neg_tol)) begin
Td_p = (V(V_swing)/I(I_p))*C_load;
end
else if ((V(Vin) <= V(Vdd) + pos_tol) && (V(Vin) >= V(Vdd) + neg_tol))
Td_n = (V(V_swing)/I(I_p))*C_load;
@(cross(V(Vin)-(V(V_swing)/2),+1)) begin
V_ph = V(Vss);
end
@(cross(V(Vin)-(V(V_swing)/2),-1)) begin
V_ph = V(Vdd);
end
V(Vout) <+ transition(V_ph,0,Td_p,Td_n);
end
endmodule
module multiphase_vco(Vbias_p,Vbias_n,Vdd,Vss, out);
parameter integer ZERO_BIT = 0;
parameter integer NO_STAGE = 11 from [3:67];
genvar i;
input Vbias_p,Vbias_n,Vdd,Vss;
output [NO_STAGE-1:0] out;
voltage Vbias_p,Vbias_n,Vdd,Vss;
electrical [NO_STAGE-1:0] out;
electrical [NO_STAGE:0]ph_out;
generate
for (i =1;i<=11;i=i+1) begin
cur_starved_delay #(.C_load(C_load),.Kp(Kp),.Kn(Kn),.Vt(Vt),.pos_tol(pos_tol),.neg_tol(neg_tol))
D_i(.Vin(ph_out[i-1]),.Vbias_p(Vbias_p),.Vbias_n(Vbias_n),.Vdd(Vdd),.Vss(Vss),.Vout(ph_out));
end
endgenerate
analog begin
V(ph_out[0]) <+ V(ph_out[NO_STAGE]);
@(initial_step) begin
V(ph_out[ZERO_BIT]) <+ V(Vss);
end
end
endmodule
output Vout;
current I_p,I_n;
analog begin
end
V_ph = V(Vss);
end
V_ph = V(Vdd);
end
end
endmodule
genvar i;
generate
end
endgenerate
analog begin
end
end
endmodule
