Help me choose a DSC and a programmer for it
mastertushar
Member level 3
Mumbai, India
hi .. i want to make Digital Smps by using Digital Signal Controller ... there are many company making DSC(Digital Signal Controller)... like texas i, microchip.. ect..
plz tell me if anyone doing it already..
1)which DSC is better to use ??
2)i know the basic of SMPS actually i m designing it now but in old analog passion so which books or applocation note i have to read??
3)if i want to use microchip dcPIC 30/33 for the purpose then which compiler is used for that?? which programmer i have to buy for that.. i am a student and i have to desing it... thats why i need ur help.. thanx in advance.....
Digital power supply
The only DSC that I used is the dsPIC33. I recommend that for SMPS you use the dsPIC33GS series of microcontrollers, which is dedicated to SMPS applications.
Take a look at this:
For books, read those by Marty Brown, Ron Lenk, Mack, Pressman and Keith Billings.
Hope this helps.
Tahmid.
    mastertushar
^^^ veryy thanx for ur kind reply.... and i checked it.. but which programmer i have to bye for programming dcPIC33??
and which compiler??
Programmer : PicKit 2/3 or ICD.
Compiler : MPLAB C30
Good luck
    mastertushar
For programming, I recommend that you use Microchip's PICKit2. With that you can program any PIC microcontroller.
Compiler choice is upto you. The codes provided in the links are in C30. You can use that, or you can use mikroBASIC or mikroC.
Mostly, I use mikroBASIC.
Hope this helps.
Tahmid.
    mastertushar
Re: Digital power supply
Hope this helps.
Tahmid.
thanx but is pickit 2 supports dsPIC33??
and as compile changes the will change?? right??
Added after 5 minutes:
Good luck
thanx .. i have downloaded MPLAB IDE v8.36 but when i put some c program code in it ... it ask for programmer...that i cant understant.. is there need to bye pickit2 before compiling?? thanx in advance
No, you can compile/simulate/debug yu code without any programmers. But make sure that u installed Microchip C30 compiler.
Ya. But new chips from microchip are no longer supported by pickit2.
See the link below.
PicKit3 can program most of PIC controllers including PIC32 that pickit2 can't.
Good Luck.
Yes pickit2 supports dsPIC33. You can use this now and it's pretty cheap.
But if you feel you'll need one that can program the newer ones, you can get pickit3, but from different forums, I have read that it has some problems and pickit2 is preferred to pickit3.
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
yes i also heard that pickit 3 has some bug
