+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Full Member level 3
    Points: 2,806, Level: 12
    Join Date
    Dec 2005
    Posts
    174
    Points
    2,806
    Level
    12
    Time domain filtering with Matlab
    If I have collected a series of sample data acquired at 10000samples/sec, within it there is a 1Khz signal I would like to extract.
    How should i go about it using matlab and build a filter and hilbert transfofrm?
    any literature i could look for?
    thanks
    •   Alt22nd June 2010, 16:54
      advertising
  2. #2
    Junior Member level 3
    Points: 903, Level: 6
    Join Date
    Jun 2010
    Irvine
    Posts
    28
    Points
    903
    Level
    Re: Time domain filtering with Matlab
    There is "fdatool" available in MATLAB.
    It is a GUI that helps you in designing the filter - You can select the BW/ Cutoff as you need. You can visualize the complete frequency response.
    Then you can export those coefficients to workspace - to say, variable 'num'.
    then you can use, filter() command in MATLAB.
    Please let me know if you need further assistance.
    •   Alt23rd June 2010, 18:15
      advertising
  3. #3
    Super Moderator
    Points: 70,402, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,520
    Points
    70,402
    Level
    64
    If you already have the samples and know the rate they were taken, I would have thought FFT was the best solution.
    Brian.
    •   Alt24th June 2010, 08:46
      advertising
  4. #4
    Full Member level 3
    Join Date
    Dec 2005
    Posts
    174
    Points
    2,806
    Level
    12
    Quote Originally Posted by betwixt
    Brian.
    as in direct fft to obtain the spectrum? do we need a window?
  5. #5
    Newbie level 5
    Points: 321, Level: 3
    Join Date
    May 2011
    Posts
    8
    Points
    321
    Level
    i have data in time domain , i want to filter some data (peaks in the time domain plot) by specifying filters start time and stop time , which way i should proceed in matlab.
    please help
    thanks
